OBC PPPP
BristolE30
Post Sat Oct 10, 2020 6:52 pm
Hey zone
My 13 button OBC is displaying the PPPP error code. What does this mean and is something damaged? It was after jump starting the car due to a flat battery.
I also replaced the regulator on the alternator as it was giving a weak voltage. Could it be that?
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
BristolE30
Post Sat Oct 10, 2020 7:28 pm
Also I might add, in the haste to get the car jumped and running again, there was a brief moment where we connected the leads to wrong terminals on battery due to the colours of cables being opposite on my friends car. His neutral was red and live was black. After the spark we read the terminals and swapped them back. Seemed no harm done until I read the PPPP a few hours later..
BMW E30 316 ‘87
Bristol, UK
Post Sat Oct 10, 2020 8:31 pm
AAAA and PPPP are the OBC's fault displays. On the few occasions I've seen it, disconnecting the battery and reconnecting sorted it, but I fear you might not be so lucky.
BristolE30
Post Sun Oct 11, 2020 12:06 am
Brianmoooore wrote: ↑
Do you know what causes the fault code? Is there something burnt out inside the OBC?
BMW E30 316 ‘87
Bristol, UK
BristolE30
Post Sun Oct 11, 2020 12:34 pm
Is there an OVP reverse polarity relay on these?
BMW E30 316 ‘87
Bristol, UK
Post Sun Oct 11, 2020 3:01 pm
I'm not familiar with the internal circuitry of the OBC, but if you're lucky, the power in will lead to a simple voltage regulator consisting of a resistor and a zener diode, both of which are likely to be knackered.
BristolE30
Post Sun Oct 11, 2020 3:37 pm
Interesting okay. So do E30’s not have any reverse polarity protection? My brothers Mercedes had a fuse/relay OVP by the battery for such an occasion.
BMW E30 316 ‘87
Bristol, UK
Post Sun Oct 11, 2020 6:27 pm
Post Sun Oct 11, 2020 8:21 pm
Speedtouch wrote: ↑
Zone Wiki suggests this:
https://www.e30zone.net/e30wiki/index.p ... AAA.2FPPPP
Definitely worth a try. Forgot that the OBC has a reset button.
BristolE30
Post Mon Oct 12, 2020 11:46 pm
Will give it a try and report back!
BMW E30 316 ‘87
Bristol, UK
