DME Repair
bernard
Post Thu Oct 08, 2020 6:07 pm
Hi
Garage has diagnosed DME failure, fuel pump and relay both deemed fine
I've looked for spares on ebay ((my car is a 325i with a Motortronic 1.3) and posted in the wanted section but there appear to be a few companies offering repairs - wondered if anyone else had tried this?
Phil
flybynite
Post Thu Oct 08, 2020 7:24 pm
They do come up now and again but not as often as they used to.
If you get no luck you could try these guys who have done a few repairs for guys here
https://www.atpelectronics.co.uk/c/bmw-325-petrol-ecu
Post Fri Oct 09, 2020 12:02 am
bernard wrote: ↑
Hi
Phil
I know nothing of how good your garage is or otherwise, but in my experience a diagnosis of "DME failure" is often a euphemism for "we haven't a clue what's wrong"
DME's are extremely reliable, and the only thing that normally fails (apart from idle control failure on one particular E30 ECU) is one of the coil drivers, as a result of being 'spiked'.
Yours may, of course, be the exception to the rule.
Post Fri Oct 09, 2020 4:09 pm
Brianmoooore wrote: ↑
Bernard mentions in another post that it's a 380 ECU, which are known to blow diodes in the idle control circuit.
You would be better off looking for the earlier and better 0 261 200 173 ECU, which is identical in operation but doesn't have the troublesome extra diodes.
Also, did the garage check the DME relay? That is switched by the ignition and feeds power to the ECU.
https://www.e30zone.net/e30wiki/index.php?title=DME
Post Fri Oct 09, 2020 5:56 pm
Speedtouch wrote: ↑
Or a 172, from a 2.0 litre, which may be cheaper and have greater availability, plus one of your 2.5 chips.
bernard
Post Fri Oct 09, 2020 9:28 pm
[/quote]
[/quote]
I did ask, yes they did, it seems to be an injection control issue
bernard
Post Fri Oct 09, 2020 9:30 pm
Speedtouch wrote: ↑
Are these all interchangable? Wasn't aware of that and there are a lot more used 261200173 DMEs on ebay
Chipping was on the cards
Post Fri Oct 09, 2020 9:40 pm
173 and 380 are directly interchangeable, and a 172 only differs from a 173 in the software contained in the 'chip'.
What, exactly, is the problem with your car?
Post Sat Oct 10, 2020 9:56 am
I expect it is a non running fuel pump situation, hopefully the crank sensor has been checked/changed
Send me a pm if you want the ECU testing as described on the ATP link.
Post Sat Oct 10, 2020 11:17 am
Any of the later six-pot Motronic 1.3 ECUs (172/173/179/380/381) are all interchangeable if you fit a suitable EPROM chip.
Shaheenem
Post Sat Oct 10, 2020 11:54 am
I have a spare 173 325i ECU. Only issue is i am in South Africa.
Post Sat Oct 10, 2020 12:16 pm
All the last several posts above are probably irrelevant, since I doubt even more that the OP actually needs one.
