Gear broken in automatic antenna
Kalimsnor
Post Sat Oct 03, 2020 8:53 pm
Hi. I think one or two parts of the gear broke from my automatic antenna. Here's a video, make sure to listen to the sound.
Do I need to get a whole new motor or can I change the gear?
P.S. it stops making noise like 5 seconds after the antenna reached the top
Kalimsnor
Post Tue Oct 06, 2020 4:06 pm
Any advice on the matter? A whole new automatic antenna will set me back quite a bit I'm afraid, I'd prefer to fix the gears. Hoping someone has experience with this.
flybynite
Post Tue Oct 06, 2020 5:29 pm
Kalimsnor wrote: ↑
What make of aerial is it?
You can try to take it apart and clean it, too many people 'lubricate it' with all sorts of stuff that just bungs it up
If it is a Hirschmann you might have some luck getting some second-hand parts but the only new part I know that might be available is a replacement rod itself. If it is some other make I would not bother. Just get yourself an Auta 2050 and be done with it
Kalimsnor
Post Tue Oct 13, 2020 11:08 am
flybynite wrote: ↑
Kalimsnor wrote: ↑
This is actually a great tip, thanks a lot. I'll go search for an Auta 2050, thanks!
twright
Post Tue Oct 13, 2020 12:41 pm
I have bought a generic antenna replacement from Amazon for $50. Mine worked great, but I don't know how long it will last because I sold the car.
Kalimsnor
Post Mon May 10, 2021 2:44 pm
In case anyone finds this thread and has the same probem: I ended up purchasing this specific Hirschmann antenna and it's basically plug-and-play for an E30: https://www.conrad.nl/p/hirschmann-car- ... ouw-319288
At first I had purchased a new antenna mast, in the hopes of keeping it OEM. But this new mast broke after 3 days.
