Help please. No power to fuel pump. Fuse 11 blows when jumping 87 and 30
e30-EVN
Post Sun Oct 04, 2020 5:17 pm
Pulling my hair out with this now lol.
I've been through my wiring I'm sure it's the same as it was before!
Tested the fuel pump relay. Thick red wire has 12v, jumped pins 87 and 30 and the fuel pump fuse blew!
Fuel pump is a new item that only did around 500 miles if that.! Its a quantum high flow pump.
I'm not getting any power to the fuel pump plug. And fuse 11 shows earth which is really pickling me now
Someone please help.
It's almost as if the fuel pump circuit is earthed and not live
Post Sun Oct 04, 2020 7:59 pm
Remove fuse 11 and connect a 12 volt lamp between the inner socket of the fuse holder and body earth.
Crank the engine. Does the lamp light?
e30-EVN
Post Sun Oct 04, 2020 8:18 pm
I will try in the morning and report straight back Brian
