As per subject, is there any out there ?
There are plenty PDF download on internet, but they are all for LHD cars.
Trying to sort out some electrical issue for a M52B28 transplanted E30, but can't find the right ETM
RHD E30 electrical troubleshooting manual
Satan
What are the issues as there are some knowledgeable bods on here, I am not one of them though ;o)))))
ecsk
I'm having intermittence electrical playing up problem. Suddenly turn indicator light, horn, wiper, brake light all stopped working,
Tap the fuse box a few times they come back to work. Sometime it last longer before playing up again.
I really don't want to pull the fuse box out
It's a 1985 convertible with M52B28 transplanted.
ecsk
The closest ETM that I can base on is the 1988 325i convertible version. The four components that stopped working is control by 4 adjacent fuses (4, 5, 6, 7) .
I suspect it could be loose contact problem or there are rust under the fuse box, is there any cheap solution?
Satan
Have you replaced the fuses and sewed them properly?
Could also be a bad earth, BrianMoooore is the go to guy so hopefully he will see your thread.
flybynite
Satan
Also run a cable from the earth on the fusebox to the body,
May also be worthwhile speaking to DanThe
ecsk
I repeated my questions in Technical help section.
