and we're off !
Tzantushka
Great image.
All you need is an dude dressed in 80's fashions and that picture looks like it has come out of a sales brochure.
tha881
Hinny
Awesome stuff that mate, actually jealous. Switzerland has got to be up there as one of the most beautiful and yet, still very well connected places I've ever been. Keep it up
Pics. and mention of the Gotthard Pass stirred up some distant memories in the far recesses of my brain, so I dragged up Google maps and Wikipedia to do some checks. Google maps confirmed that it must have been the pass I'd gone through, since I'd gone from Switzerland to Monza (Milan) via Como, but I didn't recall the road being quite the quality and width of the road in the pics, but I did remember seeing lots of construction going on near the road every now and then along the route.
Checking with Wikipedia, I see that the pass in the pics. was only opened in '77, and since I was there in '73 ( JP Lotus first and second, in front of the Tifosi - lucky to get out of the place alive), I must have driven the 1830 Tremola pass, and all the roadworks I saw along the way must have been the construction of the current pass.
paultv
Hey Brian,
When i drove back from Lugano I took the old A2 which passes through many small villages, as you travel you catch site of the newer A2 autostrada and are offered many points to enter it.
I stayed on the old road which admittedly took a long time but was really pretty and very quiet.
As you ascend the serpentine route into the mountains above the tunnel entrance the road is super twisty and many sections are still cobbled !!
Its only when you get to the top that you find the covered new sections, and the work is still ongoing.
Paul
Paul
paultv
Oh no!
Heading for London for 4 days!
Lets see if I'm Corona Free!
Paul
Paul
Satan
Where in Londinium will you be?
paultv
Now in sunny Southwark...by the shard...must try for a suitable photo!
Paul
Paul
minesapint
Hi Paul, love hearing about your long runs on the continent, wondered what mileage you had on the car, so checked on dvla mot history. @ Apl 19 122144 mls.
Yet in Aug 09 it had 157360 mls
Presume it had an engine replacement then? Was this in your ownership?
paultv
I lnow its odd, I bought the car in 2013 from a bloke in Lincolnshire ...it was a heap of cobbled bits...had been re sprayed at some point...and showed signs of crash damage...also mot history starts in the early 2000's so maybe it was an import ??
More likely the clock pod was switched...so I think the original 160k should be added to the 50k ive done...the bottom end is sounding ready for a rebuild...thrust bearings are worn for sure although compression is still very good.
This winter its coming out for a look see.
I just have one more BIG run in two weeks time...but I'm not gonna jinx it !!
Paul
Paul
kieran325
I’m hoping to be back over to Baden Baden in 2 weeks, not sure whether to take the M3 or the M5 but I need to cross France to avoid the quarantine without stopping off and I don’t want to ring the neck of the M3.
Satan
Sail to Holland,
Reminds me I really should do a trip to Hamburg.
paultv
France Holland and Belgium are all no go when travelling to the UK... I went through all three, went off the motorway in the country for a slash in a field..like most other UK bound drivers.
Border geezers asked where I'd come from, told them and they were fine...you've got to do your covid "visa" no more than 48 hours before you re enter the UK...its a long and detailed on line form they say you can't travel without...they didnt ask to see mine.
Paul
Paul
paultv
I'm a country lad - I normally do the same at home.
paultv
Lived in France for a few years....I'm familiar with the "odeur des pissoirs"
Paul
Paul
kieran325
That’s my normal route is the overnight ferry from Hull to Zeebrugge with a gentle drive to Baden Baden with no time restraints.
In the past I’ve been catching the Eurotunnel but it’s a 4hr plus drive from Manchester and I normally tip toe to Bruges for night on the chemic before the drive the day after.
On this occasion with quarantine looming I’m best to use the M5 as I can tip toe through France and be in Baden Baden late afternoon relaxing in the Spa. Just in case the quarantine becomes an issue in Germany then I can load up and give it beans to get back to the Eurotunnel and make it back to the UK, in normal circumstances the E30 M3 would be first choice but I don’t fancy ripping the M3 to make time up on a long jaunt.
coopman
Sounds like a good lifestyle.
paultv
Here we go!!
Sporting the cheapo Depo's for UK travel!
Paul
Paul
I`ve got these on mine !!!!!!!
Pretty good to be honest,
paultv
It's true Mart, I fit them for UK travel and MOT - and used them for a year when I re built my Bosch set - good as new - still shiny no leaks - can't grumble for the cost.
Paul
Paul
You don't use the LH/RH adjustment feature of the OEM lights?
I cut down the ridiculously long peg that the beam unit has to swing over at first, so that I didn't have to unscrew the securing screws so far, and later made up a set with springs holding the beam unit in place, that could be swapped over in seconds.
paultv
I usually use the LH/RH onthe Bosch set but I have to clean them up and re spray the rings so I took 'em out for a while - also I still want to test the LED H1's from the Bettecarlighting chaps -
Also, good idea Brian, it is a pain having to withdraw the screws completely to switch them around... must have a look at a mod as you describe.
Very cool "Victorian" style aerial ... it took me a while to line this up for the shot !!
Problem is all I can get is old Music Hall on medium wave....
Paul
Paul
paultv
Well I'm off again tomorrow ...early start...here's the old gal outside the shop after a fresh oil change and a good once over under the hood as well as a full drive train check up.
This is a long one...I'll post some shots on the way and see who can rightly guess where I am.
Paul
Paul
paultv
So where am I today???
Paul:-)
Paul:-)
ah
At the side of the road,somewhere in Italy.
Born on the 23 April 1990 320i Alpinweiss ll kabriolett! (SOLD BUT NOT FORGOTTEN !)
kieran325
Paul, slightly off topic but can I ask a question about a trip next week.
I’m heading over to Baden Baden for 3 nights and I was going to leave Calais and transit through France direct to BB. Which way would you go via Aachen, Luxembourg or direct through France ?
tha881
davidt
- Pompey Council 4 door deviant
Lake Como Italy.
Satan
Speaking to the cop that pulled you over?
minesapint
Lugano
paultv
Yes indeed, Lugano water front it is!!
next location coming shortly...
Paul
Paul
