Garage clearout
Wessie
Post Tue Aug 04, 2020 7:19 pm
-2x rear seat belt 2-door €10,-
-Cream speaker covers sedan €15,-
-Black speaker covers sedan €15,-
-Plate above glove box €5,-
-Headlight grill passenger side €5,-
-Airduct passenger side €5,-
-Buttons etc €2,50 each
-Mirror without glass €15,-
-Mirror with glass €25,-
-Window mechanism driver side front €25,-
-Rearsprings 15,- each set (2 different heights)
-Power steering pump operation unknown €25,-
-ABS pump operation unknown + cut cable €25,-
-Mirror triangle inside €2,50
-M42 ignition coil block €25,-
Have photos of each part separate.
So send pb with which part then I send the photos.
-The left and right air guide tubes M-Tech 2 towards brakes.
1 new and 1 used
New € 119.87 each
I offer them for € 100 the 2
-Gray edition belts
A set of a 2-door € 125, -
A set of a touring / sedan € 100, -
This set has different types of front belts and the spring of 1 of the rear has
probably jumped out, you can try to transfer mechanism.
-ECU/DME
Bosch 0261200172 / BMW 1726388
Suitable for:
E30 320i 2.0 129 Pk
E34 520i 2.0 129 Pk
Motor: M20B20
Asking: €30,- each
I'm located in The Netherlands, near Ijmuiden and Hoek van Holland, but can send also
bilal-ali
Post Thu Aug 13, 2020 10:46 pm
Do you still have air ducts?
