The evolution of ‘Errol’ the 325i Cabriolet
Tzantushka
Love the progress.
BTW - do you have heated washer nozzles?
(the connectors and wiring loom on the bonnet)
bexwoods
Hi, yeah the exhaust is Boysen, same as when the car was new!
Dolphin Grey 325i Cabriolet
Check out my restoration thread!
viewtopic.php?f=112&t=279183&p=2964331#p2964331
bexwoods
Getting there.....
bexwoods
Yep!Tzantushka wrote: ↑Sun Aug 02, 2020 10:37 amLove the progress.
e30Passion
Original BMW E30 OEM exhaust for the majority of the e30 series are made by a company called Eberspacher. Some cars like the 323i & Alpina's etc. might have Boyssen exhaust.
Here are the rest of the OEM manufacturers for the rest of the e30 parts..
Boge: Shocks, bushings, top mount.
Sachs: Shocks, clutch, fan clutch, bushings, top mount.
Febi Bilstein: Shocks.
Lemforder: Control arms, bushings, drop links, tie rods, top mount.
THL: Waterpump, crank & rod bearing.
Bremi: Distributor cap & rotor, Ignition leads.
Karlyn STI: Ignition leads.
Bosch: Lots of electrical stuff, from spark plugs to headlights, ECU, ignition coil, switches, sensors, relais etc.
Hella: Headlights, switches, sensors, relais, taillighthousings, headlight carriers, other electrical- plastic and metal parts.
Jurid-Textar-Ate: Braking parts like discs, pads, booster, master & slave cil.
Lucas Girling-Ate: Brake calipers/rear cylinders.
TRW: Repair kit calipers
Eberspaecher-Boysson: Exhaust.
SKF: Wheelbearings & other bearings.
ZF: Gearbox, steeringrack & pump.
Vickers: Steeringpump.
Behr: Radiator & thermostat. Fan clutch.
Goetze: Headgasket set, other gaskets, pistonrings.
Mahle: Pistons.
Contitech: Auxilairy belts, timing belt.
Mann-Mahle: Filters.
Wahler: Thermostat.
Getrag: Gearbox.
Motometer: Instrument cluster & gauges.
VDO: Instrument cluster & gauges, engine sensors.
Hirschman: Antenna.
Blaupunkt: Radiounits
Nokia: Speakers
Brose: Electric motors power windows
Ebasto: Electric motor roof
Metzeler: Aerodynamic accessories (M-tech) like spoilers, skirts etc.
Pfeba: Aerodynamic accessories
Gerhardi: Facelift Edition side skirts
Stabilus: Bonnet shock & seat adjuster shocks.
Ribe: Headbolts
Ullringer: Alarmsystems
flybynite
Good informatione30Passion wrote: ↑Tue Aug 04, 2020 12:16 amHere are the rest of the OEM manufacturers for the rest of the e30 parts..
That was not my question, I wanted to know the make supplied by BMW now, as you probably know BMW have supplied 'genuine parts' exhausts made by different people over the years , some of which were not best quality.e30Passion wrote: ↑Tue Aug 04, 2020 12:16 amOriginal BMW E30 OEM exhaust for the majority of the e30 series are made by a company called Eberspacher. Some cars like the 323i & Alpina's etc. might have Boyssen exhaust.
I had 2 of them
e30Passion
I would not go to BMW for exhaust parts anyway. You pay top price for something that is worth less then half of what they charge.. no matter who made it! Go to the internet for Eberspacher or anything OEM (now you know the OEM brand used) unless you dont care about the cash spending. My backbox is now little of 10 years old from new (from the internet for just 70 Euro's) but it is rotten again with holes in it so i too need another one again.
Didn't know necessarily that BMW supplied different brand exhausts to be honest. I am in the Netherlands so dont know if we have the same problem. I ques you will only find out when you go and buy one.
I would highly advise new OEM exhaust parts to be ceramic coated and treated inside and out, especially the backbox. To the very least a good sanding before heat resistant paint, including the brackets. Using stainless steel nuts and bolts to mount the thing is also not a bad idea. The originals are rubbish.
Cleaning that bonnet must have been a pain in the arse
bexwoods
The correct exhaust for a 1989 325i cab is manufactured by Boysen. Not Eberspacher.e30Passion wrote: ↑Tue Aug 04, 2020 11:20 pmI would not go to BMW for exhaust parts anyway. You pay top price for something that is worth less then half of what they charge.. no matter who made it! Go to the internet for Eberspacher or anything OEM (now you know the OEM brand used) unless you dont care about the cash spending. My backbox is now little of 10 years old from new (from the internet for just 70 Euro's) but it is rotten again with holes in it so i too need another one again.
Cleaning that bonnet must have been a pain in the arse![]()
Everything thing I’m replacing on my car is OEM and most of it purchased from BMW. The exhaust system I’ve brought will be high temp painted, not ceramic coated. Can’t justify the extra cost really and in my experience painted keeps it in good nick!
Anyway, this is a thread on my resto progress not a place to discuss right and wrong
bexwoods
Another job ticked off! Bonnet insulation replaced!
bexwoods
Finished bonnet
Stripping down the engine bay this weekend! Wish me luck
Rusty318IS
Bonnet looking great. I hadn’t realised I was missing a timing belt sticker in this location, I shall be ordering myself one!
Looking forward to seeing more engine bay, good luck and keep up the great work.
bexwoods
ThanksRusty318IS wrote: ↑Sat Aug 22, 2020 11:56 amBonnet looking great. I hadn’t realised I was missing a timing belt sticker in this location, I shall be ordering myself one!
Lots of ‘proper mechanics’ to do now
bexwoods
Productive day stripping down the engine bay (as much as I can while I still need to move the car about!) for a good clean.
Note this is the only time you will ever see me smile before cleaning!!
Up on the ramp after my ‘staycation’ for a FULL service! Exciting!
ocde30
Great work on this car Bex. The bonnet looks great - hard work I know but worth it. Hope you do some before and after pictures in the engine bay as it is always interesting and encouraging to see the improvements made possible by a good clean. Good thread.
rix313
Hey Bex! Good to chat to you on Instagram, look forward to seeing the car!
bexwoods
Likewise
bexwoods
Thanks hun!! I’ll do my best with pics, lighting isn’t great in our shed tho.
These are ‘before’ ....
ocde30
Good luck with the cleaning - more fun than welding and scraping off rust.
I took the liberty of doing a bit of colour correction....
bexwoods
Thanks hun. The lighting in our shed is crappy for photos!
It’s going up on the ramp today so guna get my hands properly grubby..... finally
bexwoods
Good progress today, lots of parts removed heading towards a timing belt change.
Everything given a thorough check over, and all worn/broken/past their best parts will be replaced when we rebuild
Is that a 15A fuse I can see in position 11?
bexwoods
Absolutely no idea.... why?
Because a 15A fuse won't blow in the event of seized pump, whereas the correct 7.5A one will. 15A ones tend to get fitted when a pump starts to fail and occasionally blows the fuse. The uninformed person's response to a blowing fuse is often to fit a bigger one, which in this case 'fixes' the problem, but, of course, removes much of the protection against fire from the circuit. Pump eventually fails completely and gets replaced, but the 15A fuse rarely does.
Brianmoooore wrote: ↑Mon Sep 07, 2020 2:22 pmBecause a 15A fuse won't blow in the event of seized pump, whereas the correct 7.5A one will. 15A ones tend to get fitted when a pump starts to fail and occasionally blows the fuse. The uninformed person's response to a blowing fuse is often to fit a bigger one, which in this case 'fixes' the problem, but, of course, removes much of the protection against fire from the circuit. Pump eventually fails completely and gets replaced, but the 15A fuse rarely does.
bexwoods
Thanks for the advice!Brianmoooore wrote: ↑Mon Sep 07, 2020 2:22 pmBecause a 15A fuse won't blow in the event of seized pump, whereas the correct 7.5A one will. 15A ones tend to get fitted when a pump starts to fail and occasionally blows the fuse. The uninformed person's response to a blowing fuse is often to fit a bigger one, which in this case 'fixes' the problem, but, of course, removes much of the protection against fire from the circuit. Pump eventually fails completely and gets replaced, but the 15A fuse rarely does.
rix313
How is it so wide spread and common that a 15A fuse gets fitted? Is it a bit like the 318iS galvanised chassis joke someone made once, and for some reason it became gospel? It seems to come up an awful lot. When using good old Google, there a couple of links to printed media with both 7.5 and 15 amp fuses listed for position 11.Brianmoooore wrote: ↑Mon Sep 07, 2020 2:22 pmBecause a 15A fuse won't blow in the event of seized pump, whereas the correct 7.5A one will. 15A ones tend to get fitted when a pump starts to fail and occasionally blows the fuse. The uninformed person's response to a blowing fuse is often to fit a bigger one, which in this case 'fixes' the problem, but, of course, removes much of the protection against fire from the circuit. Pump eventually fails completely and gets replaced, but the 15A fuse rarely does.
The older E30s that used two fuel pumps (lift in the tank and pressure in front of LH rear wheel) used a 15 fuse, so there are fuse charts in existence that show that for fuse 11, but the main reason is what I described - a failing fuel pump. I've written on here before about the two weeks I once spent touring Europe with a deteriorating pump that needed frequent attacks with a blunt instrument to re start it. The first thing I did on that occasion was change the fuse to 15A, but I did change it back again when I replaced the pump.
bexwoods
Swapped it over an no issues ;) thanks for the heads up!Brianmoooore wrote: ↑Fri Sep 11, 2020 10:40 pmThe older E30s that used two fuel pumps (lift in the tank and pressure in front of LH rear wheel) used a 15 fuse, so there are fuse charts in existence that show that for fuse 11, but the main reason is what I described - a failing fuel pump. I've written on here before about the two weeks I once spent touring Europe with a deteriorating pump that needed frequent attacks with a blunt instrument to re start it. The first thing I did on that occasion was change the fuse to 15A, but I did change it back again when I replaced the pump.
bexwoods
Good progress stripping the engine bay down (to send some bits off for blasting/ultrasonic cleaning/getting ready to replace) today!
A few new jobs added to my existing list, but nothing major...
twenty
So the only exhaust I can find on schmiedmann.com is https://www.schmiedmann.com/en/bmw-E30/ ... ct=325UDST which according to them is made by Imasaf in Spain. Did you order this or something else?bexwoods wrote: ↑Thu Jul 02, 2020 12:01 amYeah it’s three parts, not replacing the down pipe just yet though as it’s in good nic and I need the £s for elsewhere!Rusty318IS wrote: ↑Wed Jul 01, 2020 8:58 pmNice to see pics of the OEM exhaust, I’d like to replace mine with one but it’s quite an outlay eh,
I note like mine your car is a late 325 and the new system appears to be a 3 piece, does this mean BMW no longer supply the 2 piece?
I think keep it grey paint.
BMW quoted me almost a grand for the front and rear silencer. Got gen ones through Schmeidmann for just over £600. They’re worth checking out!
bexwoods
A few pics from the last week....
The student and the teacher: Wiring loom out of the way!
Look at the shiny!! (Almost ready for the final ‘bits’ to come off ready for blasting and paint!)
bexwoods
These are the ones I brought:twenty wrote: ↑Tue Sep 22, 2020 1:27 pmSo the only exhaust I can find on schmiedmann.com is https://www.schmiedmann.com/en/bmw-E30/ ... ct=325UDST which according to them is made by Imasaf in Spain. Did you order this or something else?bexwoods wrote: ↑Thu Jul 02, 2020 12:01 amYeah it’s three parts, not replacing the down pipe just yet though as it’s in good nic and I need the £s for elsewhere!Rusty318IS wrote: ↑Wed Jul 01, 2020 8:58 pmNice to see pics of the OEM exhaust, I’d like to replace mine with one but it’s quite an outlay eh,
https://www.schmiedmann.com/en/product/ ... -1-709-372
And
https://www.schmiedmann.com/en/product/ ... -1-707-048
twenty
BMW supplies the 2 piece system.Rusty318IS wrote: ↑Wed Jul 01, 2020 8:58 pmNice to see pics of the OEM exhaust, I’d like to replace mine with one but it’s quite an outlay eh,
Resonator + downpipe: 18101719068 - 444 euro
Muffler: 18101719244 - 384 euro
twenty
Cheers for that. It appears that BMW is pushing the more expensive 2 piece system - clearly 3 price parts are still available and cheaper.bexwoods wrote: ↑Sun Sep 27, 2020 6:31 pmThese are the ones I brought:twenty wrote: ↑Tue Sep 22, 2020 1:27 pmSo the only exhaust I can find on schmiedmann.com is https://www.schmiedmann.com/en/bmw-E30/ ... ct=325UDST which according to them is made by Imasaf in Spain. Did you order this or something else?bexwoods wrote: ↑Thu Jul 02, 2020 12:01 am
And
Did the silencer/muffler come with any manufacturer information, e.g. Bosal/IMASAF?
Thanks and keep up the excellent work!
bexwoods
I ordered the parts I linked above, listed as OEM parts, were delivered with all the beemer stickers and part numbers stamped on them and they're made by Boysen.
Honestly can't fault Schmeidmann, they've been great for the bigger priced items that from BMW direct cost a fortune!
