Price list for parts
Looking for genuine BMW parts at discounted prices? Try here!
Mattkennedy
Post Wed Jul 29, 2020 12:07 am
Hi! I've just bought and E30 and was wondering if I could get a parts price breakdown for this long old list please! :D (apologies its so long) and do you sell the oil pump shims still at all?
servicing parts
11611734683 - base intake gasket
11611721346 x 2 - mid intake gasket
11231717952 - fan belt
11317624063 - timing belt kit
11311734677 - timing belt kit screw (part of above?)
11537511580 - thermostat
11531265084 - thermostat "o" ring
rocker cover
11121716993 - oil cap
1121727726 - rocker gasket
oil pump area
11141714611 - oil pump rotor
11141714613 - oil pump cover
07129903401 - cover screw
11141247393 - control valve
111411706809 - coil spring
11141247397 - spacer bush
07119934625 - lock ring washer
clips/trim
07509063124 x 10 - arch clipnut
63171367868 x 4 - wheel liner nut
07129901652 x 4 body arch nut
71111117440 - tool kit plastic screw
oil filter area
12618611273 - oil pressure switch
11421709800 - oil filter gasket
11421709513 - "o" ring (actuator)
11421741000 - "o" ring filter housing
sump area
11131709815 - sump gasket
1137535106 - drain bolt
07119963151 - drain washer
11431287541 - dip stick "o" ring lower
11431715558 - dip stick "o" ring upper
sunroof gasket set
54121903725 - all round gasket
54128106928 - front gasket
54121906999 - rear gasket
trim
51488103798 - sound insulation
51321888173 - LHS pillar trim
51321888174 - RHS pillar trim
51721922471 - LHS gasket
51721922472 - RHS gasket
51131906568 - rubber seal
51361911447 - rubber seal
51131922743 - left cover
51131922744 - right cover
Many thanks
Matt
Cotswoldbmw
Post Fri Jul 31, 2020 10:28 am
Hello Matt
I will start through your list, can you PM me your email address so I can email you direct please. And I will need vehicle details to look up
the shims.
Jon
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
Cotswoldbmw
Post Fri Jul 31, 2020 3:55 pm
Hello Matt
The total will be £709.20 for all of the items, send me your email and I can send you the detail.
Jon
Cotswold BMW Parts
01242 335365
