engine throttle and vac settings,320i auto
Ukhozi
Post Thu Jul 30, 2020 11:52 am
On my '87 320i automatic there are a two cables on the throttle, I get the accelerator cable and it's stop screw but the other one seems to be connected to the auto box and I can't find a setting for it- Also what's the setting for the stop screw on the vacuum device that seems to stop stalling.
The other part that's a bit unknown is the attachment on the inlet above the rocker cover that has two pipe on it and a screw adjustment inside, After I replaced the breather pipe from rocker to throttle body I had to screw it almost right in to bring the tickover down.
Everyone has the right to reach the level of their own incompetence.
JimmyMc
Post Thu Jul 30, 2020 6:02 pm
I believe the second cable you mentioned is the kick down cable, and has an adjustment range listed in the Haynes manual.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
JimmyMc
Post Thu Jul 30, 2020 6:04 pm
I’m not sure about the second question, I don’t have them on mine (1990 320i auto).
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
