Road trip spares
Radar
Post Thu Jul 16, 2020 6:51 pm
What do you normally pack for a road trip?
I pack:
1/4 drive set up to 13mm + long extension
Pliers (needle & bull nose)
Vice grips
Side cutters
Small lengths of wire + chocolate block connectors
Electrical tape
Gaffer tape
Cable ties
ATF / brake fluid / oil / coolant / screen wash
Shop towels
Jump box
And I buy European break down cover.
What else would you pack for a 2000 mile euro road trip?
E30 M3 Convertible
911 Turbo S
CLS63 Shooting brake
paultv
Post Thu Jul 16, 2020 7:15 pm
I always take the spare, the jack, a replacement fuel pump, a replacement CPS and a DME relay with spare alternator belt and power steering belt as well as the on-board tool kit.
So basically things that stop the car and could be an issue to obtain on the side of the road...
Oh yeah spare bulb kit which you should carry anyway and a high viz jacket, also an alcohol test kit at least in France!
Otherwise all fluids and other general crap are available everywhere - best not to over think this as your car is pretty reliable - if it's averagely well maintained.
and 2K miles is a trip to the shop, it just lasts a bit longer!!
Paul :-)
Radar
Post Thu Jul 16, 2020 7:37 pm
paultv wrote: ↑
Paul :-)
Cunning plan.
Have belts in stock.
Don’t have CPS, I have a whole fuse box from a parts car, so I’ll have the relays from that.
FYI breath test kit is no longer required in France since the politician who proposed it was found to have interests in a breath test manufacturer... gotta love the French
E30 M3 Convertible
911 Turbo S
BenHar
Post Thu Jul 16, 2020 8:09 pm
Self amalgamating tape.
Ben
tha881
Post Thu Jul 16, 2020 8:42 pm
We want details of the road trip, not what supplies you're packing in your boot :D
Spare wheel, jack, tyre inflator, oil, most tools, work light, shop roll, oil, 12v phone charger, high vis, warning triangle, that's mostly what I can remember. And a good old fashioned map in case you cant get any signal. I also have a tag for the tolls in France which is a lifesaver.
flybynite
Post Thu Jul 16, 2020 8:45 pm
Big Hammer
Tow Rope
One of the best things I keep in all our cars is a magnetic LED light, like these
https://www.screwfix.com/p/nebo-ne6373- ... -aaa/9107v
Sticks to the car, shines down on your wheel change etc. Shines bright red if you are stuck in the middle of the road. Used it in anger twice now.
Radar
Post Thu Jul 16, 2020 9:08 pm
I am guilty of not taking paper maps with me. I’ve done this trip before so I think I’m safe staying digital.
I always carry my headlight. Though snap on magnetic light is a fine idea and doesn’t take much space.
Hi vis and bulb kit go without saying.
Yes to Halfords tyre pump.
If I need a big hammer or tow rope... I’ll call for recovery. Definitely take a regular hammer.
As I take my car fridge ... I’m long on 12v chargers and accessories.
E30 M3 Convertible
911 Turbo S
JungleGus
Post Thu Jul 16, 2020 10:35 pm
Judging by my performance on the side of the A2 today, carrying a soldering iron and a jump start pack with a 240V plug is a trip saver...
I carry most of my tool kit and a few fluids/towels etc...in one of those laundry tubs in the rear. Less room for wine but it's nice to get places
Satan
Post Fri Jul 17, 2020 11:45 am
Credit card, cash and recovery.
tha881
Post Fri Jul 17, 2020 7:23 pm
What's peoples opinions on using the E10 fuel on the continent? Should we avoid it and run super unleaded on an m20 engine?
paultv
Post Fri Jul 17, 2020 8:17 pm
I generally use E10 but give the car Super when I think it would like a treat!!
I'm pretty sure E10 is fine.
Paul:-)
tha881
Post Fri Jul 17, 2020 10:20 pm
Thanks Paul, I did read some articles stating that it wasnt suitable for older vehicles. That said, I used it last year without realising the extra ethanol content, and it ran fine.
Post Sat Jul 18, 2020 12:03 am
paultv wrote: ↑
Paul :-)
Add a bit of wire and self amalgamating tape to that list, The CPS failing is the one thing that can stop you in your tracks that isn't the result of poor maintenance, and a fuel pump is useful, although a failing one can usually be cajoled into working for a few hundreds of miles (this one I know from experience).
I don't carry a DME rely - that can be bypassed by a couple of wire links, as can any other relay, and you shouldn't need belts if maintenance s up to date.
E10 petrol is fine in an injected E30, although it will cause corrosion of the fuel tank in the long term.
boiliebasher
Post Sat Jul 18, 2020 1:47 pm
Been doing euro road trips for years in classic vehicles. I would definitely bring spare fan belt and a set of spanners too. Also I'd personally go 3/8" socket set rather than 1/4" set and also take a breaker bar so you don't end smashing your only ratchet to pieces undoing a stuck nut/bolt
Edit: personally I wouldn't take all the fluids you mentioned either as it takes up a lot of unnecessary room and potentially messy if spilt.
Honestly literally every single petrol station or super market on the continent stocks basic automotive fluids if you're stuck and 2k miles is nothing in the grand scheme of things.
As long as car is up together there's no reason in my opinion why you would need to top up any fluids on your car doing that kind of mileage.
boiliebasher
Post Sat Jul 18, 2020 1:50 pm
Oh and E10 is fine. I believe in UK it's E5 by now anyway so ain't gonna make much odds. M20's are dinosaur engines anyway and aren't exactly high performance racing engines that require premium octane fuel lol
paultv
Post Sat Jul 18, 2020 2:45 pm
......a decent torch for that night time nightmare breakdown........
boiliebasher
Post Sat Jul 18, 2020 3:08 pm
paultv wrote: ↑
Good shout.
I do a lot of night fishing so usually have one with me anyway.
Head torch being the way forwards as you can work on the car "hands free" so more useful than standard torch IMHO
paultv
Post Sat Jul 18, 2020 3:42 pm
I'm usually carrying my camera gear on long runs including battery driven LED photography lamps and stands - way to go!
Paul :-)
Satan
Post Sat Jul 18, 2020 5:31 pm
paultv wrote: ↑
Paul :-)
You are Don Roobles AICMFP :mad: :banana:
paultv
Post Sat Jul 18, 2020 6:53 pm
I'll give you £2:50 !!!!
ChrisHC
E30Zone Contributor
Post Thu Jul 23, 2020 5:26 pm
I always carry in the car a short length of 15mm copper tube and two small Jubilee clips as recommended by Brian Moore in order to by-pass the heater valve if it starts leaking.
Sonatine
Post Sat Jul 25, 2020 8:16 pm
My spare is a 14” bottletop and I have 15” basketweaves fitted. Would you guys get a proper 15” spare?
Post Sat Jul 25, 2020 9:24 pm
The 'correct' spare is a 14" steel.
How often have you needed a spare? I drive between a quarter and a third of my total mileage on the roads of Europe, and I've only needed a spare wheel once. Unfortunately, the spare I had was a space saver (fuel tank occupies spare wheel well), it was a Sunday, the original tyre was shredded, and when I eventually got the wheel to a French tyre fitter, I was informed that French law requires identical tyres on the same axle, so I had to wait three days for a new tyre. By that time, I'd taken nearly half the tread off the space saver.
Radar
Post Sun Jul 26, 2020 7:38 am
Brianmoooore wrote: ↑
I just got a 16” spare, now with the same tyre as the others. Unfortunately as it’s a directional tyre I had to choose whether it would be left or right sided 😕
E30 M3 Convertible
911 Turbo S
flybynite
Post Sun Jul 26, 2020 8:17 am
Radar wrote: ↑
Every time I have needed a spare it has been on the gutter side, potholes, and rubbish in the gutter, rocks or concrete hidden in the grass verge
Not going to be end of the world to drive a bit the wring way on the tyre.
I've got a spare that won't fit over the front brakes on one of mine, I need to do a double swap!
Radar
Post Sun Jul 26, 2020 10:21 am
flybynite wrote: ↑
Radar wrote: ↑
I chose right side, as most of my big trips are in Europe for that very reason.
E30 M3 Convertible
911 Turbo S
Post Sun Jul 26, 2020 11:05 am
flybynite wrote: ↑
Same with my space saver. It won't clear the front caliper.
Radar
Post Fri Aug 14, 2020 12:24 pm
Dammit, rain got in somewhere bad in yesterday's storms. E30 staying at home. Have to take a modern. At least it didn't happen en route. :?
E30 M3 Convertible
911 Turbo S
Post Fri Aug 14, 2020 12:45 pm
Radar wrote: ↑
Sh1t !! whats the problem/s ??
tha881
Post Fri Aug 14, 2020 3:52 pm
ChrisHC wrote: ↑
This is an excellent idea, it could really save a road trip from disaster
Radar wrote: ↑
So what set of wheels are replacing the e30 on the trip?
Radar
Post Sat Aug 15, 2020 3:19 am
martauto wrote: ↑
Radar wrote: ↑
Starts with central locking again. Will investigate on return.
E30 M3 Convertible
911 Turbo S
