Keyless entry mod
BristolE30
Hey guys
Thinking of purchasing one of those cheap easy to install keyless entry mods on the 325. Anyone had any experience with them? Are they just as safe as any other keyless car?
Appreciate any input.
Jo
Jo
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
- Brianmoooore
Easy to connect. ALL the wires you need to access are located in the area behind the glovebox, where there's room for the module.
Several key fob styles available, including one that closely resembles the genuine hexagonal fob, that can be fitted with a key blade that can be cut to suit your car.
Have fitted several over the years, all all have been 100% reliable.
BristolE30
Thanks guys for the encouragement, sounds like I’ll crack on then!Brianmoooore wrote: ↑Mon Nov 25, 2019 11:30 pmEasy to connect. ALL the wires you need to access are located in the area behind the glovebox, where there's room for the module.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Every now and again my Rightclick fails to work after heavy rain. The module is behind the glovebox so the reason for this is hard to fathom, anyway the central locking still works with a key, so it is not that ECU, and normal service is resumed when it gets drier.
BristolE30
- Brianmoooore
Deadlock is activated by a microswitch behind the driver's key barrel. It operates a second motor on each other door actuator which locks the mechanism solid from inside and out. There is no deadlock on the fuel flap, and the deadlock in the driver's door and boot/tailgate are activated mechanically by the key.
It wouldn't be difficult to use the 'spare' function on the Rightclick modules to operate the deadlocks on the other doors, but, for the reasons above, it wouldn't dedlock the driver's door.
- Tzantushka
Possible to provide a link to the thread for the right click solution?
I’m in the market for remote solution and having trouble finding a E30 friendly solution.
- Brianmoooore
Some instructions for fitting it in this thread: viewtopic.php?f=1&t=266585&p=2885337&hi ... k#p2885337
Ben
Ben
- Satan
Added level of security.BristolE30 wrote: ↑Thu Nov 28, 2019 12:30 pmWhat does the deadlock achieve? I know it’s something to do with it also being locked on the inside?
- Brianmoooore
The main thing it does is to prevent a potential thief pulling out the top of the door frame, dropping a wire over the internal lock button, and pulling it up - a procedure that I've seen my brother in law perform in about thirty seconds. The mushroom headed buttons on the E30 make this easier than on later models, where the mushroom head has been dispensed with.BristolE30 wrote: ↑Thu Nov 28, 2019 12:30 pmWhat does the deadlock achieve? I know it’s something to do with it also being locked on the inside?
Cloggy Saint
When they fitted the alarm to my E36 they took the buttons and the short wire rod out completely, fitted an appropriate size flashing LED into the hole. Can't say I missed them but it was 2-door and usually only me in it.Cloggy Saint wrote: ↑Sat Nov 30, 2019 12:30 amI assume the later model button shares a thread size with the E30, would a straight swap be possible?
BristolE30
Nice do you know what the correct blank key code is?Brianmoooore wrote: ↑Fri Nov 29, 2019 1:17 pmhttps://www.rclick.co.uk/shop/index.php ... er=product
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
Sanchez
Brian said HU50 On another thread.BristolE30 wrote: ↑Sat Nov 30, 2019 6:36 pmNice do you know what the correct blank key code is?Brianmoooore wrote: ↑Fri Nov 29, 2019 1:17 pmhttps://www.rclick.co.uk/shop/index.php ... er=product
- Tzantushka
Ordered the KE670 remote kit from Rclick.co.uk.
Also specified the HU 50 code as the blanks for the key.
Let's see how they go.
steve_k
- Contact:
might be ordering that myself soon, got used to that on my daily (mk5 jetta).Tzantushka wrote: ↑Sun Mar 29, 2020 3:47 amOrdered the KE670 remote kit from Rclick.co.uk.
- Tzantushka
I am getting ready to fit the Right Click central locking kit when it turns up.
But I'd like to make sure I know what I'm doing beforehand.
Based on Brian's tips and the collective wisdom in this thread - I have marked-up the 2020 version of the Right Click wiring diagram.
Does this look right to the experienced experts?
- Brianmoooore
Looks about right, other than you need to include the two diodes on the indicator circuit, and connect the blue/red and blue/black to the cathode (stripe) ends of the diodes, otherwise you will have no indicators, but three ways of turning on your hazard lights.
- Tzantushka
Thanks - have updated the diagram, below, so it's clearer the diodes are before splicing into the indicator circuits.Brianmoooore wrote: ↑Sat Apr 04, 2020 1:42 pmLooks about right, other than you need to include the two diodes on the indicator circuit, and connect the blue/red and blue/black to the cathode (stripe) ends of the diodes, otherwise you will have no indicators, but three ways of turning on your hazard lights.
Whilst I was upgrading the front speakers & waiting for the Right Click remote kit to arrive, I noticed that someone else has been in the (LH) door un/lock circuit before.
Uh Oh... Scotch Locks:
Yep, had to remove the remnants of the old alarm first.
(More pics inmy progress thread)
II fitted a simple (cheap) central locking unit off of Ebay for about 25€ and hooked it into the drivers door wires and the ignition wiring and never a days problem, but DO NOT use scotch locks, strip and solder all joints or you will get failures.
Everyone has the right to reach the level of their own incompetence.
Did you fit this, and did it work okay? Just had mine arrive. Thanks.Tzantushka wrote: ↑Wed May 13, 2020 11:44 amThanks - have updated the diagram, below, so it's clearer the diodes are before splicing into the indicator circuits.Brianmoooore wrote: ↑Sat Apr 04, 2020 1:42 pmLooks about right, other than you need to include the two diodes on the indicator circuit, and connect the blue/red and blue/black to the cathode (stripe) ends of the diodes, otherwise you will have no indicators, but three ways of turning on your hazard lights.
Previous cars:
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
E46, E90x2, F31
Current cars:
F31 340i, F21, E30
- Tzantushka
Yes.
Works very well - best mod so far.
Few observations for those interested:
Kit is pretty good - everything you need is in the box.
Wiring loom is longer than you need (if installing behind the glovebox on RHD cars).
Even includes the diodes for the indicator circuit (flashers) and inline fuse.
Key fob 'looks' BMW - it doesn't 'feel' very BMW - very light in the hand.
Good range and positive click with buttons - just feels very light.
Only negative is the specified key blank doesn't actually fit & work when cut by an auto locksmith.
1. Key is chrome plated brass and not as strong as the OE stainless keys
2. The slots are cut too close together and doesn't fit the barrel well (and the lock wafers don't properly engage)
See difference between OE key blank (LH) & the Right Click one.
That's OK - I'll just remove the Right Click key and use the remote fob & OE key.
Long term plan - I'll cut the OE key and modify the key shank to fit the Right Click remote.
If you follow Brianmoores installation guidelines in the above links and wiring diagram image - you can't go wrong.
Electronics box can be tucked up high in the dash behind the LH vent (for good remote reception range).
Earth point was spot on, lock-unlock wires, +12V live and indicator circuits all close by.
The bright blue LED indicator is a bit gaudy - but can be easily swapped out and modified for a bezel mount LED in a dash switch blank.
On mine it came with flip out keys but soon broke away, very thin sides, it also has a third button for a boot popper, (requires a separate solenoid). Buying a fixed key is best. Over complicating by getting an alarm/locking unit is a waste, unless the car is outside you house no one takes any notice and can be silenced in 10 seconds anyway. Been fitting alarms for 30 years.
BristolE30
My right click module has just arrived but I’ve come across a little hurdle. It seems some P/O has installed a remote locking unit/alarm already but I don’t think they’ve used wires behind glove box from what I can see. What’s the best way of working out what each of these exisiting wires does? Then I could just replace the dud box with the right click one. Little bit new to the electric circuit stuff
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
BristolE30
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
- Brianmoooore
Always good fun unpicking other peoples bodge ups! At least it looks tidily done from the little bit I can see, even if not connected to the points BMW intended.
You'll have to unwrap the black tape and split the bunch of wires until you come back to where they individually connect to the OE wiring, and then show us some more pics.
BristolE30
Yea it doesn’t look like an awful job to be fair. Is there anyway of determining what each wire does without unwrapping it? I’ve got a multi meter ....Brianmoooore wrote: ↑Fri Jun 26, 2020 10:47 pmAlways good fun unpicking other peoples bodge ups! At least it looks tidily done from the little bit I can see, even if not connected to the points BMW intended.
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
- Brianmoooore
It would be possible without unwrapping, but you still won't know if they're connected correctly. Also, it's bad practice (and potentially extremely confusing) to add extension wiring onto existing extension wiring.
rix313
- Contact:
Great thread this. I discovered a similar looking module under my dash but have long ago dispensed of the fobs the car came with as it never worked from the day I had it. Perhaps time to refresh it.
- Brianmoooore
BristolE30
Yes I know it’s bad... but I did it. Worked out which was the unlock and lock along with the 3 grounds and indicators. All wired up and working a treat!Brianmoooore wrote: ↑Sat Jun 27, 2020 2:17 pmIt would be possible without unwrapping, but you still won't know if they're connected correctly. Also, it's bad practice (and potentially extremely confusing) to add extension wiring onto existing extension wiring.
Does anyone have a solution for the key blades not being correct? Can we get correct blades?
BMW E30 316 ‘87
BMW E30 325i ‘88
Bristol, UK
BMW E30 325i ‘88
Bristol, UK
