First off, does anyone know where I can get some more of the clips that hold the fog blanks + brake air scoops on? I need 8 but only have 5...
And a second question to start, I have this in the boot but no idea why, where's it from?
A third question (which I don't have a pic for) is how do the bloody mudflaps mount? They've got that weird metal bracket with a kind of hook at the bottom, all I can guess is that the bracket used to hook on to/around the factory jacking point (which is now gone)? Does anyone have some pics as I can't see a nice way of mounting these...
On to the valance, unfortunately on the new one the brackets for mounting the splash guard at each side are either mullered, or gone:
Just going to ignore that for now and sort later if required, running out of time/daylight!
Not surprised the valance has some issues, as judging by the following picture, the previous owner was a fecking muppet:
Why are people the way they are!?!!? Morons...
Anyway, for some reason the previous owner also removed all the bumper lip clips, so a new bag of those was bought for a fiver and fit perfect
Tip for putting the lip on: start at one side, rather than the middle, or you end up with this and have to redo it:
One of the longest jobs at the moment is scouring the garage for all the fiddly parts, and trying to remember what was lost/broken. After much searching, finally found these:
Meaning the car now looks like this
Annoyingly when I went to put the last screw in (it's always the last one) for the N/S wing, the spire clip on one of the two L shaped brackets snapped, so I'm going to have to do undo all the other bolts and see if I can get a new spire clip on, or will have to take the bumper + wing back off this week to sort.
Some small jobs, the new badge arrived, was a touch dirty under the old one:
Instagram styleeee:
Another small job, I noticed some of the fuses weren't looking the best, so they got replaced with new ones. Annoyingly I didn't have any of the brown 7.5 ones, so will get those later.
One of the next small jobs will be sorting the vents.
The left vent doesn't move at all, the right vent just flops about. According to the E30 Zone FB group (and some YT videos) this can sometimes be sorted by removing them and putting some paper or rubber washers in, but not sure about the stuck one. Going to remove this week and see.
Last update for today is some welding, been putting this off for a while as it's visible (unlike the rest which is under 1" of seam sealer), but needs must.
Decided to start with the upper one, as working around that jacking bracket and the stupid bulge it has in the sill is a nightmare, or at least it was on the other side.
Thought about doing it as a thin separate piece along the top, to make it easier to recreate that lip it has. Decided instead to just stack some sheet metal on the bench, put the patch over it, then hammer the daylights out of it.
"That'll do"
Unfortunately I ran out of light before I got chance to finish tidying it up, there's 1-2 tiny pinholes to fill too.
One thing I will say is why did I take this long to revert back to 0.6mm wire! I've been using 0.8 as the machine had a load of it already inside, but in the interest of less holes I picked up a 5KG reel of 0.6mm, and haven't blown a hole yet. Not only that but I've put the power setting from 1 to 2, so there's now less holes and better penetration - kicking myself for not doing this earlier, oh well.
Need to finish smoothing that first job, then it's time to tackle the 2nd dreaded bit of that sill around the bracket, once that's done though, that should be all the front end welding done, I can finish faffing getting the splash guards, mud guards, and inner arches on, then drop the car at the front, lift the back and start that. The back of the car won't get nearly as much love as the front as I want this on the road before it's too cold to work on it on a driveway - so the rear will probably just get a brake refresh, new springs/dampers, and maybe new hubs/bearings.
Some bits I don't have pics of are the seats being bolted in, the new horns are in and wired up, the blower works etc, and all the indicators are now functioning - so I think there's no electrical issues anymore (for now).
