Which spark plugs for my 325e '85
Kalimsnor
Post Mon May 04, 2020 9:37 am
Hi,
My sparkpugs are ready to be replaced. I don't have a lot of time lately to be doing repairs, but this is minor enough to do at home. Can someone tell me which sparkplugs are ideal for my 325e from 1985, type 1?
I took them all out to do a compressiontest and took a quick video. 5 of them look rougly like this one, properly brown:
The 5th cyl was the only one that looked different, a lot less healthy: - can anyone tell me why one of the 6 spark plugs is different from the others?
Thanks!
BristolE30
Post Mon May 04, 2020 9:58 am
I usually just pop my reg into Eurocarparts, Auto doc etc and use the standard Bosch ones that come up!
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
Kalimsnor
Post Mon May 04, 2020 2:54 pm
I read online that the Bosch sparkplugs are not good for E30s, because they often break on our models.
These seem to be compatible to my 325e, what do you guys think of DENSO? https://www.autodoc.nl/denso/1667065 Or maybe these NGKs? https://www.autodoc.nl/ngk/1042577
BristolE30
Post Mon May 04, 2020 5:54 pm
Kalimsnor wrote: ↑
I’ve used only Bosch on both my E30’s (316 and 325) and never had an issue. They rolled off the factory floor with Bosch, so Bosch would be fine.
NGK are also a good alternative, but it’s much for muchness in my opinion.
BMW E30 316 ‘87
Bristol, UK
Kalimsnor
Post Thu May 07, 2020 9:34 am
BristolE30 wrote: ↑
Kalimsnor wrote: ↑
Thanks for the help, I'll go get those Bosch ones then!
Post Thu May 07, 2020 10:42 am
You need to address why your engine is running rich! Unless you habitually make very short journeys that don't get the engine up to working temperature, there's something wrong.
The 'different' one might well be oil contamination.
fixedwheelnut
Post Thu May 07, 2020 11:50 am
Brianmoooore wrote: ↑
Popular cause is corrosion in the round wiring plug below the inlet manifold, it causes a variation in the reading from the engine temperature sensor.
Kalimsnor
Post Thu May 07, 2020 12:01 pm
Ended up having to get the DENSO, Bosch was out of stock. https://www.autodoc.nl/denso/1667065
Thanks for the tip Brian. I'll go look into that next week!
fixedwheelnut wrote: ↑
Don't think it's related, but my temp sensor is broken - see viewtopic.php?f=2&t=279833&p=2967088
Post Thu May 07, 2020 1:49 pm
Kalimsnor wrote: ↑
Could be. Different sensor, but they lie alongside each other, and wiring for both goes through the C191.
You should unplug the engine ECU and identify pin 45 of the plug, which has a brown/red wire going to it. Measure the resistance from this pin to a good body earth, then reconnect the plug, start the engine and run it up to full temperature, then stop the engine, quickly disconnect the ECU plug
again, and re measure the resistance.
