Been a long time since I have had the chance to work properly on the E30 again - it has been on stands for far too long and was covered in moss. So some traffic film removed and a lot of elbow grease later she is looking clean and ready to be worked on again.
I have new lemforder control arms and the rubber lollipop bushes - I tried to hammer/ push them on whilst on the ground but that didnt seem to work so I put them on the subframe and struts and made a bent threaded bar contraption to get the bushes on:
I started on the passenger side and after bending the bar a bit, I managed to get it all the way on to the control arm only to find...
I put it on the wrong way! Yes I know what a muppet, so I decided to order Sealey Gear Puller set: https://www.ebay.co.uk/itm/132529965233?var=0
which took some time to come and really struggling to get it back off - it pulls on the rubber but doesn't seem to budge much.
Now I am trying to put the drivers side on my threaded bar solution is struggling this time.
So I am getting a bit frustrated
Feel like I have a few options
1 - drill the rubber area and pull it off and then cut the remaining rubber with a hacksaw
2 - pull both the control arms back off the car and retry the threaded bar thingy
3 - sack off the rubber bushes and use poly which seem to be much easier to install?? (never done it befor)
Any ideas or tool suggestions (within a reasonable price range) would be much apprecaited!
