Pipe from Servo to Intake Manifold
MickoE30
Post Tue Apr 21, 2020 9:34 am
Hi,
Can any one confirm the Part No. for the pipe outlined in below pic?
Car is a 1986 320i (Auto).
The pipe is torn and I want to order a replacement, but can't identify it on the REAL OEM Diagrams.
Post Tue Apr 21, 2020 10:32 am
The early 320i is a nightmare of bits of rubber hose, as you probably know, and I try not to get involved with them!
Have you entered your VIN into the ETK version you're using? Although the diagram will be the same, the list below should only show the parts fitted to your car.
The hose is ordinary straight vacuum hose (12mm?), and should be available by the metre from motor factors or ebay as an alternative.
MickoE30
Post Tue Apr 21, 2020 11:44 am
Brian,
Many thanks for your response!
Yes, I had entered the VIN into the search.
eBay version will do nicely!
Thanks again.
reggid
Post Sun Apr 26, 2020 7:19 am
i think it is this 34331115926. simply 12x19mm vacuum hose
E30 325is with M20B31
