M20 Thermostat Housing
MickoE30
Post Sun Apr 19, 2020 7:56 pm
Hi,
I am after a Thermostat housing for an M20 (lower hose connector corroded and fell off!)
Car is a 1986 320i, but are they the same for all M20 engines?
After a good 2nd hand one, or can anyone point me to a new aftermarket supplier?
j2b
Post Sun Apr 19, 2020 8:46 pm
Rockauto american supplier i got one for mine,the only difference being is the're 2 extra threaded holes which have to be blanked , after ordering was on my door step in 2/3 days . link here
https://www.rockauto.com/
89 more door 6 pot
MickoE30
Post Sun Apr 19, 2020 9:47 pm
Thanks,
I will have a look.
How did you block off the extra holes?
j2b
Post Mon Apr 20, 2020 2:30 pm
MickoE30 wrote: ↑
Thanks,
I will have a look.
You're welcome,
From memory i think i used spare brown and a spare blue sensors, had to cut the end off one if i recall was a while ago now, if not an easier solution would be to take it to a hardware store and match up some short threaded bolts with a sealing washer.
89 more door 6 pot
964russ
Post Tue Apr 21, 2020 8:51 am
£90 from stealers
