BMW 318 IS
Place where dreams come true - threads will be deleted 60 days after last post.
Razler3is
Post Fri Mar 06, 2020 10:49 am
BMW 318 IS
5 SPEED MANUAL
E30
1990
M42/44 1.8 4 CYLINDER 16 VALVE PETROL
ALPINE MP3 USB HEADUNIT, ORIGINAL SIZED PIONEER SPEAKERS
STAINLESS STEEL EXHAUST SYSTEM FROM TUBULAR MANIFOLD BACK, HAND MADE BY ADVANCED AUTOMOTIVE SYSTEMS
ENGINE REBUILT AT 184K, DONER M44 ENGINE CLOCKS USED ~58K, NOW ~62.5K MILES
ENGINE REBUILT USING UPDATED COMPONENTS FROM M44 ENGINE (CHAIN GUIDE INSTEAD OF GEAR, HIGHER CAPACITY OIL PUMP ETC) BUT RETAINING M42 FORGED CRANK AND RODS
GENUINE BMW PARTS USED DURING REBUILD
M20 LIGHTENED FLYWHEEL AND CLUTCH
SHORT SHIFTER GEAR LEVER
ECU REMAP
CLUBSPORT QUICK STEERING RACK WITH CORRECT FITTING KIT
NUMAX BATTERY
K&N PANEL AIR FILTER
EIBACH 30MM LOWERING SPRINGS
F+R TEXTAR DISKS & PAGID PADS FITTED ~100MILES AGO
STAINLESS BRAIDED FLEXY BRAKE HOSES, KUNIFER PIPES
GENUINE BRAKE BACKING PLATES
FRONT WISHBONE M3 ADJUSTABLE POLY BUSHES
REAR SUBFRAME AND FRONT WISHBONES OVERHAULED REPLACING BUSHES TO POLY'S
15" BBS CROSS-SPOKES RECONDITIONED, TOYO PROXY TYRES 2K USE.
14" BBS CROSS-SPOKE SPARE
ALL SUSPENSION COMPONENTS HAVE BEEN CLEANED AND PAINTED
ALL COMMON AREAS TO RUST HAVE BEEN PROFESSIONALLY REPAIRED
FULL RESPRAY ~ 8 YEARS AGO MAINLY GARAGED SINCE
TOAD A1606 CAT1 ALARM & IMMOBILISER SYSTEM
X2 KEYS AND ALARM FOBS
LESS THAN A MONTH OLD MOT
ACQUIRED 2009 ONLY AROUND 3K MILES SINCE, ONLY 1K IN THE LAST 8 YAERS
GARAGE STORED UNDER COVER.
TASTEFULLY UPGRADED, ORIGINAL LOOK KEPT
£6999
CONTACT ON WHATSAPP ; 07718737264 FOR MORE INFO / PHOTOS IF REQUIRED.
Post Fri Mar 06, 2020 11:57 am
Where are you based please , very roughly will do :cool:
Razler3is
Post Fri Mar 06, 2020 3:05 pm
Northumberland
Razler3is
Post Sun Mar 29, 2020 3:17 pm
No interest???
Post Sun Mar 29, 2020 3:23 pm
Razler3is wrote: ↑
No interest???
Very "silly" times mate, or this would fly out.
Good luck .
boiliebasher
Post Sun Mar 29, 2020 6:52 pm
Agreed, that does look like a very tidy car and I would have said under normal circumstances, it would have probably sold by now.
Maybe hold off until all this covid stuff calms down and you may start getting some decent offers. GLWTS
flybynite
Post Sun Mar 29, 2020 7:27 pm
Razler3is wrote: ↑
No interest???
I think it is the wrong time to sell anything at the moment except hand-sanitizer. Even those that paid moon money for a shed full of loo roll are looking stupid at the moment as sense has finally won over and shelves are full again.
Honest opinion, the car falls between two places,
It is a bit too messed with to appeal to someone wanting to 'collect' it, lot of work to make it 'original' again and not having the original engine, may not be possible. Original paintwork is also a seller, unless it is a really good job. Missing mirror glass is only a small thing but makes it look a bit neglected.
As an engine-swapped car for someone to use as a daily it probably does not go far enough, most would probably want to swap engine and a few other bits and it is strong money for a project car, particularly at the moment.
Anything will sell, it is just the price, if you can wait 6 months things should be different,
Good luck with it though, it is still a very tidy car :thumb:
rix313
Post Mon Apr 13, 2020 10:16 pm
Looks a super clean car mate. Is the engine still 1.8 then? Be a great buy for someone! Just as soon as all this nonsense sorts itself out.
BobIzYaUncle
Post Sun May 24, 2020 11:56 pm
Is this still available. Probably a long but don't want to waste your time so I'll get streight to the point. Would you consider £5k?
BobIzYaUncle
Post Mon Jun 15, 2020 10:45 pm
My offer still stands
