BMW E30 318i M10 heating system
damers2000
Post Mon Mar 09, 2020 7:12 pm
Hi All,
Trying to find out exactly what the coolant hose layout should look like in my pre-facelift E30. The previous owner had some kind of an issue and re-routed a hose to bypass something, be so much easier to compare one that is fully functioning.
I'm in Byram, neaar Knottingley \ Castleford, West Yorkshire.
ah
Post Mon Mar 09, 2020 7:20 pm
Try putting up images of M10 318i and see what google comes up with.
damers2000
Post Mon Mar 09, 2020 7:37 pm
ah wrote: ↑
been there, done that mate but its not conclusive. The pipework I need to have a look at comes out of bulkhead and under the engine, or should do I think...... Bought a haynes manual in the hope that might help but, nope, no help at all
ah
Post Mon Mar 09, 2020 8:37 pm
Right ok, you need to get in contact with Brianmoooore,if he doesn’t know you have got real trouble.
Satan
Post Mon Mar 09, 2020 9:52 pm
Have you checked the WiKi and Realoem to get an idea?
Post Mon Mar 09, 2020 11:52 pm
damers2000 wrote: ↑
Hi All,
Pop up some pics of what you are concerned about so we can see the problem areas.
My M10 has a webber on but it may not be the original water system.
Over in Morley by the way :cool: :cool: :cool:
damers2000
Post Tue Mar 10, 2020 6:24 am
Hi all,
Thankyou for your responses so far. I've attached photo's below to show the issue. As you can see, it seems to be the lower pipe coming out of the bulkhead which is bypassing something and connecting straight into the large hose at the front of the car. Ignore the filthy engine bay, currently being restored so hopefully look a bit better soon!
Also, if a visit to Morley would help and is same coolant layout, I'm more than happy to have a ride across.
Thanks again!
Satan
Post Tue Mar 10, 2020 10:56 am
Does your heater work in the car?
damers2000
Post Tue Mar 10, 2020 12:06 pm
I dont think it does blow hot air, I cant check at minute as it's in bodyshop
Satan
Post Tue Mar 10, 2020 7:54 pm
Was just wondering if the heater matrix was bypassed if that is at all possible, clutching at straws here as I am no expert.
damers2000
Post Tue Mar 10, 2020 8:14 pm
Satan wrote: ↑
really appreciate it mate, I've been looking through the history and came across a note which said customer advised of coolant leak, so I'm guessing that that was when the faulty item was bypassed. I have no experience of E30's so completely in the dark here
Satan
Post Tue Mar 10, 2020 9:50 pm
I don't have a clue either but throwing suggestions up in the air sometimes helps garner a response.
Satan
Also circle the areas you are concerned with in RED
Post Tue Mar 10, 2020 11:27 pm
Satan wrote: ↑
Plus one mate
Post Tue Mar 10, 2020 11:33 pm
There seems to be a stack of jubilee clips joining .....Well not really sure :mad:
You are most welcome to have a look at mine ( 8O ) but with mine being the webber it may not be "stock" but let me know if you fancy a trip?
BristolE30
Post Tue Mar 10, 2020 11:47 pm
Looks almost definitely like a heater matrix bypass. Especially if it’s coming out the bulkhead. The only reason the cooling system goes into and out of the bulk head is for the heater matrix. Also confirmed by the fact you have no hot air.
Heater matrix bypass pretty common if having either a leak with matrix or problems with bleeding system and getting air trapped
BMW E30 316 ‘87
BMW E30 325i ‘88 :bmw:
Bristol, UK
BristolE30
Post Tue Mar 10, 2020 11:50 pm
Or potentially PO came up with a way for the hot coolant to get into heater matrix with more ease. Doesn’t really make sense that you have no hot air though
BMW E30 316 ‘87
Bristol, UK
Post Tue Mar 10, 2020 11:55 pm
The flow and return pipes to the heater are on the bulkhead, one just above the other, just inboard of the brake servo.
Is there anything connected to these pipes? Are the pipes actually there?
damers2000
Post Wed Mar 11, 2020 7:41 am
Thanks all very much for your help with this, when I get the car back I'll have a more thorough look at it.
The hose with all the jubilee clips is the one I am referring to, it's certainly not standard.
There are pipes going into the bulkhead, above and below each other near the brake cylinder.
Satan
Post Wed Mar 11, 2020 2:47 pm
Remember also the original clips need a special tool to fit them (I believe) so if any work was done then jubilee clips would be used as a replacement once they had been removed.
Post Wed Mar 11, 2020 6:05 pm
If there are connected hoses between the engine and the stub pipes on the bulkhead, then the heater has not been bypassed.
The feed hose to the heater runs between the back of the cylinder head and the lower stub on the bulkhead. On an M10 it is a straight hose, about 300mm long, with a right angle bend at one end and another right angle bend at the other end, facing the other way.
The hose(s) from the top stub on the bulkhead will eventually connect back to the thermostat housing, but I don't remember exactly how, and I don't have an E30 with a M10 engine any longer to check on, although I do have an M10 which still has the feed hose on it.
Every E30 I've ever worked on, and any BMW generally, has used standard jubilee type stainless steel hose clips for every application, right up to the time they introduced those horrible clip on things.
damers2000
Post Wed Mar 11, 2020 7:58 pm
when I get the car back I'm going to have to get a better look at it and try and figure out what has been removed, if anything. On some photo's I have seen, and as you also say Brian, down besides the engine there should be a metal pipe which the hose connects to. This is only something I have found out since creating this thread and having lots of helpful feedback so, once I get the car back, I'll have a more thorough look at it. The blowers did turn on when I last had the car running and even at temperature there was no heat blowing out
Satan
Post Wed Mar 11, 2020 8:52 pm
My advice get a car with a 2.5....... rarrrrrrr ;o))))
Post Wed Mar 11, 2020 11:24 pm
Satan wrote: ↑
8O 8O 8O 8O
damers2000
Post Thu Mar 12, 2020 6:31 am
Satan wrote: ↑
hahaha
My little old E30 could have no engine and i'd still love the thing, especially after I've been wanting to buy this car since I laid eyes on it way back in 1992
Post Thu Mar 12, 2020 11:00 pm
damers2000 wrote: ↑
Satan wrote: ↑
hahaha
:clap: :clap: :clap: :clap: :clap: :clap: :clap: :clap:
Post Thu Mar 12, 2020 11:06 pm
BMW chose the M10 to base their most powerful ever car engine on, (all 1200 bhp of it), not the M20.
Post Fri Mar 13, 2020 1:53 pm
Brianmoooore wrote: ↑
:cool: :cool: :cool: :cool:
Satan
Post Sat Mar 14, 2020 2:26 pm
It Mart put that in the Baur the acceleration would tear the Targa roof off...........
Post Sat Mar 14, 2020 2:30 pm
Satan wrote: ↑
M10`s are good but they dont accelerate, they change speed gradually :bmw: :bmw:
Satan
Post Sat Mar 14, 2020 11:26 pm
You'd lose your syrup as well......
damers2000
Post Fri Jul 31, 2020 7:03 am
After doing a bit more digging around, removing the air box etc so I could take closer look, I think you have hit the nail on the head with your diagnostic!
The connector to the rear of the cylinder head appears to of been blocked off with some type of silicone, although it does also appear to be damaged.
The bottom hose from the bulkhead, which is the bypass, just connects straight into the system at the front of the car behind the radiator. So, that would explain why my car has no heating, the flow from the engine is no longer there, so water would possibly just get luke warm only.
So, as far as I can see, I need two parts to correct the bypass. One of which is a connector and the other a hose. I don't suppose you would know the part numbers for these items? I think the connector is 11121250746 but can't be sure as I don't have anything to check against. I haven't got a clue what hose I would need.
In addition to the above, I would also need a replacement hose for the one which has been spliced at the front of the car which I think is 11531276541.
I have attached some photo's below but you can see to the rear of the cylinder head, there is northing other than a lump of silicone type material
minesapint
Post Fri Jul 31, 2020 11:05 am
This work to bypass the heater has been done for a reason, and that is almost certainly the heater has been leaking.
So in restoring this pipework back to original be prepared to expect a wet interior.
My approach would be to investigate the heater, it’s valve and matrix before filling it with coolant, that way you won’t get a wet back whilst grovelling on the floor of the car!
damers2000
Post Fri Jul 31, 2020 11:29 am
minesapint wrote: ↑
Thank you for this but both pipes are still present on the heater matrix so I dont think it is leaking
Post Fri Jul 31, 2020 11:31 am
If the heater isn't leaking, then why would this have been done?
At least, fill with plain water initially, rather than coolant mix.
