Guys how have you routed the danthe hose that runs around the back of the rack , above or below the engine mount?
Had a quick test fit today and looking at it mines will have to go above .I'm using rs2000 engine mounts if that matters.
TIA
m20 purple tag rack
e30-EVN
I'm quite sure mine goes under the engine arm but over the top of the subframe. I'll look through my pictures now and see if I can make it out
Dlb26
Here's some photos of how I routed my pipes from DanThe
shedrool83
Out of interest, I have had two 330`s (one a sport) and now have a 325 cab (all e46`s) and find the racks on all to be the same but really good, so what is the difference with the purple tag rack please
e30-EVN
Hi mate. It's all down the the difference in the internal parts used in the racks.
The purple tag rack from what I've seen has a stronger torsion bar and bigger holes to allow more fluid to pass through.
While they are all 3 turn racks, the purple tag rack is the one with the better feel to it hence is the one everybody wants
e30-EVN wrote: ↑Thu Feb 13, 2020 3:24 pmHi mate. It's all down the the difference in the internal parts used in the racks.
While they are all 3 turn racks, the purple tag rack is the one with the better feel to it hence is the one everybody wants![]()
Excellent !!!!
Both of the SE`s were different to the Sport.
Cheers mate
