New Rear End Install.
paultv
Post Wed Jan 08, 2020 7:53 pm
I got bored with working today.... so I started to strip out the rear end of my cabby.
After covering 25K last year, the noise from the back end has gradually got worse, with clunking and ticking from the drive shafts too.
I'm going to tackle the drive shafts, bearings, back plates, all the bushing for the rear beam and trailing arms as well as replace the flexible brake hoses as they're
well ancient.
This is what the right hand rear bearing sounds like! definite end of life!
Paul :-)
Post Thu Jan 09, 2020 3:11 pm
Buy a big amp Paul winkeye winkeye winkeye winkeye
How they run is beyond me.
paultv
Post Thu Jan 09, 2020 4:05 pm
Good idea Mart
- but ya'know its well noisy in the cabby anyway, but this was starting to bother me a lot apart from the ticking of the drive shaft UJ's and I was starting to feel it through the body.
Here's the culprit from the right side whch I liberated today, its half the outer race with extensive pitting, the inner is worse.
and here we are pulling it off !! The inner race always gets left behind on the hub as the bearing falls apart.
Paul :-)
Post Thu Jan 09, 2020 5:06 pm
Pitting !!!!!
That looks like someone having a go at arc welding.
I`m glad you were bored Paul, for your usage of the old girl it will be worth it and we know it will be done right ! :clap: :clap:
paultv
Post Thu Jan 09, 2020 5:45 pm
Thanks Mart - I'll get the other side out tomorrow if there's nothing too pressing!
and yes it's true, the last outing a few days ago was so noisy I decided it had to be now - I want it ready and worthy for the next long haul !!
paultv
Post Sat Jan 11, 2020 6:29 pm
Had time today to get it all out!
Including all the bushes! This puller has proved invaluable!!
Made my own puller for the trailing arm bushes removal - simple and quick - I'll stick a shot of it tomorrow - might help someone.
Paul :-)
Foe
Post Sat Jan 11, 2020 8:08 pm
Outstanding work Paul :thumb:
Post Sun Jan 12, 2020 2:50 pm
Foe wrote: ↑
:clap: :clap: :clap: :clap: :clap: :clap:
What are your plans for it all now Paul ?
paultv
Post Mon Jan 13, 2020 8:26 am
I'm in the process of making new brake pipes for the rear, fitting one new handbrake cable ( did the other one last year) and replacing some of the worst rusted components.
I've git an electrolysis rust removal bath running to clean up some of the most infected items, which I'll nickel plate.
Not gonna powder coat the beam and trailing arms, just clean, rust treat and paint with smooth Hammerite, they're all pretty much ok so will last past my EOL !!
New rear caliper seals going in, bushes, bearings, drive shafts and anything else I can see that's rough.
Also dropping in the refurbished 3.46:1 diff to test out, which will give me the chance to clean up the LSD.
So not that much really winkeye
Paul :-)
Post Mon Jan 13, 2020 10:36 am
Wouldn't recommend the Hammerite. It goes on too thick, is brittle, and when it chips, it's right back to bare metal. If you're treating the rust with electrolysis, it will be totally rust free, so I'd recommend a good industrial plant enamel and primer.
paultv
Post Mon Jan 13, 2020 1:01 pm
Thanks for the advice Brian - does Rust -Oleum qualify in your view??
Paul :-)
Post Mon Jan 13, 2020 1:47 pm
paultv wrote: ↑
Thanks for the advice Brian - does Rust -Oleum come qualify in your view??
Paul :-)
Haven't heard of that stuff, and Google doesn't help much - 99% of results refer to some nerd language and the rest are just ads. for buying it!
I presume it's another 'direct to rust' paint, which is designed to convert and adhere to wire brushed rust at the expense of their adhesion to clean metal. If you use electrolysis to deal with rust and are careful about positioning the anodes, there will be no trace of rust left, other than what forms before you can get the steel dry. With an ideal surface like this, nothing is going to beat good well adhering primers and top coats.
flybynite
Post Mon Jan 13, 2020 2:02 pm
Something like these ?
https://www.frost.co.uk/chassis-paints/
Particularly this
https://www.frost.co.uk/frost-frame-cha ... degreaser/
Not the cheapest but is good stuff ever cheap.
paultv
Post Thu Jan 23, 2020 2:56 pm
... and in go the new wheel bearings!
Paul :-)
paultv
Post Sat Jan 25, 2020 12:32 pm
Time to get it all back in!!
Paul :-)
Post Sat Jan 25, 2020 1:50 pm
Looks brilliant Paul, this must be a joy to fit back on?
paultv
Post Sat Jan 25, 2020 4:57 pm
It's great that everything is clean and tidy, especially the brake lines and hoses which are all new - they were in a really ugly state before and would have been difficult to replace without the rear beam being out.
The beam and trailing arms are now back in the car - tomorrow will be a bit more brake pipe work to finish off - and rebuild the hubs with the handbrake gear - then fit the "new" diff and the new drive shafts and hubs -
I'm also fitting my refurbished ABS pump - so I see a lot of bleeding to come!
Paul :-)
rix313
Post Sun Jan 26, 2020 9:05 pm
paultv wrote: ↑
Paul :-)
Angle grinder and a drift is how I often remove stuck races. Can I ask what brand puller you are using? I have been meaning to get one.
paultv wrote: ↑
Paul :-)
BEAUTIFUL. I keep telling myself that one day I will do this to my road car :bmw:
paultv
Post Sun Jan 26, 2020 9:12 pm
It was this set from Amazon...
Although this is Amazon Germany I'm sure its available in the UK.
Paul :-)
paultv
Post Mon Jan 27, 2020 11:29 am
getting the brakes assembled...slowly
Paul :-)
ocde30
Post Mon Jan 27, 2020 2:51 pm
Paul, as always, very thorough - excellent work. Are you still planning to do the big mileage in this car?
paultv
Post Mon Jan 27, 2020 5:10 pm
Absolutely - the car is great to drive and I want to continue using it on work trips in Europe - even after I had a head gasket failure 18 months ago in France -
Last year I did about 24K ... after the engine top end rebuild - looking forward to the same this year with the new rear end which was totally shagged from so much driving!
Paul :-)
ocde30
Post Wed Jan 29, 2020 9:07 am
Good for you - your car will feel transformed now after all that work. These cars were designed to be used. Looking forward to seeing more pictures from your trips around Europe.
paultv
Post Wed Jan 29, 2020 11:37 am
Finally got the diff back in this morning and all the brakes are set up and bled.
I love to see all that new pipework!
Paul :-)
Post Wed Jan 29, 2020 7:24 pm
Another work of art Paul, did you enjoy this ?? :cool: :cool: :clap: :clap:
paultv
Post Wed Jan 29, 2020 8:03 pm
Hey Mart
It's been fun, slightly cold in the garage but my winter weight BMW overalls are super snug.
I finished off today fitting one new SKF drive shaft - and whilst it fits and is well made, it was a total bastard to fit. The rubber boot is of course severely in the way of the access for the supplied hex bolts, as is the steel boot retaining strap - which all in all makes it necessary to install all the hex bolts on the bench - this requires loads of silicon spray and a hex key which is almost impossible to use as access to the head is restricted by the rubber boot - which is tough... good! but not helpful.
You need it set the wheel hub at ride height so the shafts are staight and level into the diff flanges or you are seriously buggered.
I have to attack the other one tomorrow - so I'll attempt to film my feeble efforts - this is really a warning to anyone doing this as you have zero chance of fitting the bolts under the car.
The original BMW shafts were awkward but really no problem - so be warned if considering SKF shafts.
Otherwise it's all going well, looking forward to the first test drive on Friday! after which everything will be covered in shite of course!
Paul :-)
paultv
Post Wed Feb 19, 2020 9:12 pm
Done about 300 miles and all appears well....car feels good....only thing left to sort is the rear propshaft UJ which I dont have the tools to replace as its staked.
Rebuilt 3.46 diff is totally quiet and feels like a great ratio for the motorway...I checked it today and get 138kph at 3.5k revs and 119kph at 2800rpm... car still pulls very well, so all in all a great swap....feels perfect on the autobahn, I'm getting 10kph more in 5th which sounds not much but it makes a difference whilst cruising. I have to get used to the altered gearing but it just feels right and the useless 1st gear now has a purpose!
So should I keep my 3.73 lsd I wonder?
Paul :-)
paultv
Post Thu Feb 20, 2020 6:56 pm
and I thought I'd fit a new fuel filter since it was 6 years and many miles since the last one...
Pau; :-)
tha881
Post Thu Feb 20, 2020 8:26 pm
Great work on tackling the rear end by yourself. I understand your move to a longer diff, when doing a lot of motorway miles the high revs can be annoying. Sometimes wish there was a 6th gear but as far as I know there is no easy bolt on six speed swaps.
paultv
Post Fri Mar 13, 2020 4:09 pm
So I sent my entire propshaft to VIP in Warsaw - they staked in two new universal joints and replaced the centre bearing.
It's also been painted and re balanced.
The whole thing took 8 days from pick up to delivery - at my gaff, and cost 245 euro's including shipping.
Paul :-)
Post Fri Mar 13, 2020 4:39 pm
I dont think it`s a bad price for all package Paul :cool: :cool:
Good to last a fair few years as well.
paultv
Post Fri Mar 13, 2020 4:56 pm
I reckon it's pretty good - didn't have to take it anywhere - and I don't have the gear to tackle "staked" UJ's otherwise I would have done it myself.
They were super quick and speak and write in English, German, Russian and Polish of course. They also have a UK website.
Paul :-)
flybynite
Post Fri Mar 13, 2020 5:35 pm
Looks a proper job, not much stopping it getting back on the road then? :D
paultv
Post Fri Mar 13, 2020 6:05 pm
Yes indeed - just ready for all the borders to close in Europe - my next trip was Lake Lugano in Switzerland next week - but that job has been cancelled for now...
propably not a bad thing really.
Looking forward to taking the car for a blast in a few days time!
Paul :-)
paultv
Post Mon Mar 16, 2020 4:38 pm
Took her out for a 100Km round trip to dinner and back last night - all very smooth - nice to push the ton on the autobahn, all feels good and the niggling input shaft oil seal leak I discovered
on the rebuilt diff has gone, after I replaced the seal Iftted a month ago, with one from BMW.
My fault again... I should follow my own advice - always buy BMW oil seals - NEVER use anything else -
Paul :-)
