hi i'm a new member bought an e30 325i 1989 convertible recently, this car had been stored in a garage for many years currently
in the restoration process lots of work done so far engine, cooling system, overhauled hood replacement im having trouble
with the dash intstrument cluster fuel level, temp redaings incorrect i've replaced the gauges coding plug still erractic displays
with mpg dial and also rev counter erractic any info would be much appreciated also checked the fuel pump and level sender unit both were ok
new member
BenHar
