Recommendations please
Foe
Post Mon Sep 16, 2019 11:43 am
Feeling inspired by those working on their own cars, I'm going to tackle replacing my steering rack! :?
So looking for any recommendations, for a ball joint separator to separate the tie rod end from the steering knuckle,
Satan
Post Mon Sep 16, 2019 12:56 pm
What do you do for a living as some "trades" are eligible for a Halfords Trade Card?
Tedswagon
Post Mon Sep 16, 2019 1:05 pm
Id suggest you use one you can add pressure by a screw rather than one you use a hammer.
This is better option
https://www.halfords.com/workshop-tools ... gKy7fD_BwE
This one works
https://www.halfords.com/workshop-tools ... arate-fork
But you should be able to separate with a good strike to the lower bracket on the strut.
Foe
Post Mon Sep 16, 2019 2:02 pm
Satan wrote: ↑
As it happens, I have my mates Halfords trade card!
Tedswagon wrote: ↑
This one works
Excellent thank you. I didn't like the thought of using the fork approach.
Tedswagon
Post Tue Sep 17, 2019 1:38 pm
With the fork there is a higher chance you will damage the rubber boot on the TRE. If you are replacing the TRE then - no problem - if not, best to avoid this method.
As above, a hard smack on the lower bracket of the strut should set the TRE free. No need for these tools
Foe
Post Tue Sep 17, 2019 8:57 pm
Tedswagon wrote: ↑
Yeah, I didn't like the look of the fork, just seems too brutal, but will try the hard smack approach :thumb:
