Hi all,
So I know there is a lot of info out there about this but hard to narrow down my issue.. hope some one can help?
My temp gauge was completely dead so I tightened the nut on the back and cleaned/sanded the pins on the back, it now has power but the reading is still not right, it only goes up max just over the blue marker.
Temp gauge
steve_k
- Contact:
is you engine a 6 cylinder? aka m20?
if so check the brown temp sensor in the thermostat housing,
steve_k
- Contact:
in that case test the brown temp sensor,
disconnect the plug & the gauge should read zero,
ground the sensor & the gauge should go into the red zone,
if it fails to do either of these then replace it.
- Brianmoooore
Remove the plug from the sensor and use a piece of wire to connect the single pin in the plug to a good body earth.
Have you considered the possibility that the gauge is telling the truth, and the engine isn't reaching full temperature?
