Hi,
I am currently in the process of doing the M52 swap, I pulled out the old E30 engine loom from the ECU and I noticed there are 2 additional connectors near the ECU main plug as shown in the second picture below. I would to understand what these are for, the white connector is connected to the wire as shown in first picture.
I would like know what this is form is this connector needed for doing the swap?
Doing Mr52 - Need help/advice
Cloggy Saint
Thanks for the replies, my car was auto and converted to manual
I did some more research into this, I first checked to see if any of the wires on the white connector were connected to the ECU main plug and one of the wires was connected to pin 42 which is Park/ neutral input (auto only).
- johnmaccow
Had same plug left from my 318i auto, just tucked it away and ignored it.
