Oil light on dash...
Gavla
My oil light on my dash board has started coming on once I have been driving for more than 20 minutes...
Full service with fluid changes in March this year...
What should I be looking out for?
BenHar
First thing is to check the oil level.
Ben
Ben
steve_k
first things first, what engine???
arrisbmw
yes as above oil level, but i,d say dont drive the car untill sorted.
could be as simply as a faulty sender unit.
blocked oil filter .
blocked engine oil ways .
faulty oil pump , not likely
tha881
steve_k
Gavla
Ordered a new oil pressure sensor...just in case
Ordered 5w40 Magnatex to do an oil change...just in case
Ordered a crank case breather hose...just in case
paultv
I should say the oil will be at running temp after 20 minutes driving- it takes a while to get fully hot - stick some cheap 15-40 in and see if that fixes it (this is the oil BMW originally recommended for a UK climate) - could be a worn pump or simply worn engine... but hopefully it's the sensor!
Paul
Paul
Gavla
So I changed the oil pressure sensor and changed the oil and it seems to have done the trick... fingers crossed it is not a temp fix...
Crank case breather hose will be a bonus, current one is brittle so probably needs to be changed anyway.
sweep
Oil pressure switches can leak check under the rubber boot which covers the electrical connector.
paultv
True story - mine was dribbling oil out of the rubber boot on the end of the switch.
Paul
Paul
steve_k
mine did that till i replaced the switch & it's O ring, no more dribbles now.
BenHar
If the oil level gets too low the oil pump pick up cannot reach it so there is no oil pumped round so no oil pressure and the low pressure light comes on.
Ben
Glad you got this one sorted mate,
