M52 b30 stroker rebuild back on the road
Post Fri Mar 23, 2018 9:35 pm
redsocks wrote:
magpie wrote:
Jesus325iTouring wrote:What did your engine do when the oil pump failed?
put the oil pressure light on lol :D .
well the oil chain was making a racket and i notice the oil light come on straight away so shut it down , i've had the cam tray covers off and no damage ..... sending the b30 down to Dan soon to strip it and inspect , rebuild replace where necessary no corners cut , with the oil pump upgrade i might not need to pull the engine out almost every spring :mad:
I thought it was standard to upgrade the oil pumps. Shame you had to find out the hard way
here comes the arsehole rich318i sad cunt
Post Fri Mar 23, 2018 9:40 pm
funny thing is everytime it gets broke it gets fixed and comes back bigger stronger and more bhp everytime .... keeps me entertained :D
Post Fri Mar 23, 2018 11:38 pm
oil pump bionics have arrived just waiting on the oil pump chain from from BMW and that should be the oil pump gremlims put to bed,
she'll be reet :D
frogy
Post Sat Mar 24, 2018 10:56 pm
Any pics of the oil pump gears?
Think every one would like to see the wear
frogy
Post Sat Mar 24, 2018 11:19 pm
PM'd
Post Sun Mar 25, 2018 2:23 pm
frogy wrote:PM'd
Subject: Rich318i
"mick its me if you want a chat call me. i dont slag you off mate its banter.
call me 07979225384 "
you deleted the message before i read it in my inbox but it was still there in my email notifications :mrgreen:
must've been feeling brave for 5 mins then changed ya mind eh :roll: well the miss call you have 5 mins ago is me so stop hiding under the window sill and answer the phone or call me back ....
frogy
Post Tue Apr 03, 2018 10:42 pm
well i did message you and told me to "pi2s off".
i like to know why your oil pump went kuput and others would also..
Post Tue Apr 24, 2018 11:25 pm
after putting the car away for the winter and driving it into the garage last November the b28 refuses to start ... sounds like i have fuel so a spark check is next ,
i'll have it taxed may 1st and running again with the 2.8 to get me mojo back and the b30 back in .
nowt like a 6 banger engine swap with a f00kin huge 6 speed box nailed to it to keep the e30 juices alive .
spanner rash ftw !
some more treats .
Post Tue May 08, 2018 4:58 pm
well it took all of 5 mins to get it running again ... fuse 11 needed a wiggle and the fuel pump primed straight up :D .
paid the tax and picked my two youngest kids up from school , all i could here was them shouting ... yesss Dads in the BM as they came out the school gates bless em :bmw:
Jesus325iTouring
Frog freak !
Frog freak !
Post Tue May 08, 2018 6:01 pm
My boys like a pick up from school in my V8 Beast too :D Little one liked it more last week when my wife apparently just had to over take a moped using most of the horses available :twisted:
frogy
Post Thu Sep 27, 2018 11:52 pm
So hows the M52b30 going?
Tried to ring but you left a voicemail that your going to smash my hole in you horriable litle c""t
Only want to know how the engine is going!!!
Post Fri Sep 28, 2018 9:20 am
frogy wrote:So hows the M52b30 going?
how many times have i told you to come and see me at santa pod if you want to find out , i'm there every year !
Post Sat Feb 16, 2019 9:15 pm
well it's been two full car seasons and i'm nearly into car season number 3 since my oil pump harmonic balancing failure ....... time to stop the rot and push things on .
as previously posted i've bought a a bionic drift spec oil pump shaft kit , hardened shaft and left hand thread , also sent a used set of injectors of to injectortune and had them all cleaned up ready to go in .
well to add to that i've decided to use the e36 m3 solid lightened flywheel weighing in at 5.4kgs and a sprung stage 1 e36 m3 clutch disc along with s50 clutch cover , the e30 m20 set up has been hit and miss and with the helix cover it's like a fookin stage 10 rally car spec so i'm going for sumit a bit smooother 8) .
the stroker donk was sent off down to Danthe's yesterday 15/2/2019 for him to do the fettling i;e pull apart and check everything, have the head fully overhauled , acid dipped block etc and fit the dbilas cams i bought ages ago .
i really want this engine to run like a swiss watch and Dan is the man for the job , looking forward to this year already :D
TurtleDesignTech
Post Wed Feb 20, 2019 7:16 pm
Interesting update Magpie.
Any idea when Dan will get around to it or plans for it to be back on the road?
Post Sat Feb 23, 2019 7:58 pm
i hope it's ready in good time for this season, i normally tax it april/may 1st depending on weather and if it's back together ready for the road .
Post Thu May 23, 2019 5:31 pm
some sexy pics arrived on my phone today :D
Post Thu May 23, 2019 6:23 pm
fitted a new centre bearing to the e36 328i prop i need to run a zf 5 speed [ had enough of the rattles from the 6 speed box on tick over ] , along with the prop i had to get new gear selectors so i was lucky to get both items from the same seller both parts just removed from 328i with the zf box .
test fitted the selectors on an e36 323i getrag box just see how short or notchy it is .
next is to liberate a good zf box from an e39 528i i have up the boneyard that seems nice and quiet .
Post Thu May 23, 2019 8:17 pm
i bought these dbilas cams a long time ago just after the oil pump failure ,
really good to see them finally fitted
Post Fri May 24, 2019 5:28 pm
Picked up my RG Alpenis reps today after having a double coat of ceramic coating . The brake dust should just fall off now with soapy water. Keeping them clean was a royal pita so I hope this stuff works or i just spunked £100 on promises and lies 🙈
Also dropped the prop off to be balanced up as it from two different cars £62 inc vat .
:bling: :bling:
Post Sat May 25, 2019 1:16 pm
Damd nice wheels there Mick :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool:
Post Sat Jun 01, 2019 3:54 pm
:D Cheers Mart ,
had 6 hr rd trip down to Andyboy's workshop to collect a genuine 37k zf box from a 1999 z3 2.8 .
very happy with that purchase .
the 330d wagon earning it's keep >>>
Post Tue Jun 11, 2019 5:13 pm
all the small things i'm having to buy changing to 5 speed are adding up . new slave cylinder,clutch release bearing,oil filter, fluids and some landrover defender gearbox mounts that i thought i'd try . these are solid rubber so should be ok with the oem engine mounts . If not i'll swap them out for e36 oem ones .
But on a positive note some more pics from Dan and my block is on the engine stand . 😁
Post Wed Jun 12, 2019 2:28 pm
Lovely to see all the prep that "should" go on before a project.
Post Thu Jun 13, 2019 7:07 pm
Got the m52 b28 stop gap removed along with the 6 speed box , just need to strip the b28 for its conversion parts read to refit on the b30 when it arrives
Post Fri Jun 21, 2019 9:25 pm
i'll have have the engine back next week, it's being collected on Monday .
these are the last pics Dan sent :D
i think i have everything ready to go apart from new exhaust studs that will be ordered on Monday as Cotswolds payment system was down today .
Post Fri Jun 28, 2019 8:40 pm
the engine arrived on weds morning so while i was waiting for a few days i had a good check round the car and found the rear pads badly worn so ordered new ones and got some for the front brakes as they were looking low . apart from that i decided to re underseal and waxoil the undercarriage while the engine was out .... so with no further ado i set about it late last week washing the muck/dry dust off ready for underseal .
Post Fri Jun 28, 2019 9:15 pm
right with the undersides out of the way the rear brake pads arrived today so i fitted them ,
new water pump arrived with alloy thermostat housing with 82 deg thermostat and a nice shiny new blower fan speed resistor as mines decided to only work on full belt this year ...
thursday arrived with still no exhaust studs but don't need them yet as i have to build the engine up with all it's bolt on shizzle .
had the sump acid dipped so it's nice and clean with zero old oil residue baked on .
brushed the dust off a few other boxes i've had for a while and dug out the alternator i had refurbished for this engine rebuild in march 2018 :o
and set about fitting it all
ready to plop in the hole on Monday :D
Post Tue Jul 02, 2019 6:27 pm
wey it's now in the bay and on it's mounts with the zaust manifolds on and fitted the front brake pads, i hope to have it all back together tomorrow . got an email yesterday saying my mot's ran out ffs lol :roll:
Post Thu Jul 04, 2019 6:14 pm
Final tests before I fire it up tomorrow.
Good oil pressure and the compression speaks for itself :D
[media][
Steve
Post Fri Jul 05, 2019 10:46 am
How do I keep missing these updates, epic stuff !
webmaster@e30zone.net
Post Sat Jul 06, 2019 5:11 pm
Steve wrote: ↑
what, your not subscribed yet 8-O ... :teehee:
just about ready for mot next week and off to the Scottish car show next weekend :D
Post Thu Jul 11, 2019 7:12 pm
it's Mot'd now and i've put 60 trouble free miles on , so far so good 😁
TurtleDesignTech
Post Sun Jul 28, 2019 7:03 pm
Good stuff. Hope you make the best of the summer with it now you finally have it back on the road.
Post Sat Jun 27, 2020 9:57 pm
well the old 3.25 4 clutch lsd had to go as i found it too short with the 5 speed box and after lot's of pondering and research i could get a 2.93 e36 lsd to work in an e30 casing but not possible to just swap crown wheel and pinion .
taking all this on board i purchased a complete e36 2.93 lsd, an e30 medium case diff empty case with e30 back plate then sent the lot to Danthe who built this for me >>>
after some lsd oil and a speed sensor fitted fight got real
scorchio in the tin hut ^^^^
out with the old and all that including the drive shafts as i found one had shat itself and spattered grease all over .
is a project really ever finished in you the builders own mind ????? :? :D :beer:
