ICV
DazzyA
The car has been idling at very low rev's recently, took the connector off the idle control valve today and there was no difference. Is this normal or has the ICV gone?
Pass me the spanner
DazzyA
anybody??
Pass me the spanner
billgatese30
nah, thats normal i think, try taking the plug off and removing the rubber pipes from it (with engine and ignition switched off by the way) and clean the inside out with some carb/brake cleaner spray, then reassemble and it might work a little better
DazzyA
Cheers Chris,
Will give it a try mate.
Pass me the spanner
charlE30
I had the same and tried the above method, ended up buying a new one from GSF. The difference was shall we say noticableDazzyA wrote:The car has been idling at very low rev's recently, took the connector off the idle control valve today and there was no difference. Is this normal or has the ICV gone?
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
Sharknose3
I've got a very rough idle once my 320i Touring has done 2 hours on the motorway and is warm.
I've removed the ICV and flushed it really well with carb cleaner. This made little difference so I replaced the fuel filter and that was really dirty but brought no major improvement.
Has anybody dismantled the ICV, i.e. opened the metal tabs and removed the alloy end (which accepts the 2 tubes) from the black housing (with the electrical connector at the end)?
Is any further cleaning possible than just spraying carb cleaner into the openings in the alloy end of the ICV & scrubbing everything thats visible?
If one dismantles the whole thing is it possible to get better results?
I've also replaced the blue temp sensor.
Is a new ICV the only answer or could I have another issue?
Thanks,
Sharknose
Thanks,
Sharknose
DazzyA
Mine is now ticking over at about 4000rpm's, It doesn't stall and is pretty smooth. I have renewed inlet gasket's, throttle body gasket, cleaned ICV sprayed carb cleaner so am now going to replace ICV and blue temp sensor. Can't think of anything else.
Pass me the spanner
