Warm Starting Problems ?
Billy1972
Post Fri Jun 14, 2019 9:13 am
Hi,
I've a 1987 325i vert manual which doesn't like to start when it's warm/hot?
When it's cold it fires up on the button with no hesitation and like a dream.
But once it's up to running temperature and driving around it seems to crank over for a while before she fires up?
Any idea on what I need to change or is this the norm for an old 325i?
Cloggy Saint
Post Fri Jun 14, 2019 10:48 am
This is a symptom of a fuel leak although it could be something else!. Carefully check all the lines.
aimlessrock
Post Fri Jun 14, 2019 11:10 am
when were the injectors last overhauled?
E30 320i Convertible (1989)
190 Mercedes (1988)
Billy1972
Post Fri Jun 14, 2019 12:09 pm
It has it's MOT last week and there are no issues with the fuel or fuel lines, I also had a good look underneath and they are fine.
Injectors? I only purchased the car in October and I haven't touched them and there's nothing in the history folder? If it was injectors wouldn't they also effect it when it was cold?
Cloggy Saint
Post Fri Jun 14, 2019 1:15 pm
A leaking injector(s) would show the symptoms you describe.
tha881
Post Fri Jun 14, 2019 1:35 pm
One tip is to be very gentle and quick when turning the key. It only needs the most minor of spark to fire into life. I think most m20 cars have this issue, ive had two that done it, and doing what I said always meant it fired straight away, rather than cranking it hard for 5 seconds to get it going.
Cloggy Saint
Post Fri Jun 14, 2019 1:57 pm
This isn't an M20 quirk, it' a fuel related problem!
aimlessrock
Post Fri Jun 14, 2019 2:24 pm
if the history is silent on them being overhauled (adding some injector clearer to the fuel is meaningless btw) remove them and have them cleaned, removal guide is in the wikki - its straight forward , injectortne (one of the traders) can overhaul then for about £12-15 per injector.
190 Mercedes (1988)
Billy1972
Post Fri Jun 14, 2019 3:34 pm
I'll check and clean the injectors when my mechanic friend comes over and i'll also try the gentle but quick key turn.
aimlessrock
Post Fri Jun 14, 2019 4:12 pm
unless you have the equipment to properly overhaul and more importantly balance each injector you will be wasting your time- they need cleaning via ultrasonic, balancing and fitting with new seals et al- Injectortune will do the lot for £15.00 per injector.
most zoners simply purchase a used set from a trader, have them overhauled and then fitted- the old set are then resold etc.
190 Mercedes (1988)
davidt
Pompey Council 4 door deviant
Post Fri Jun 14, 2019 9:22 pm
Agree with you 100%
