Odometer
knapmann
Post Thu Jun 06, 2019 9:02 pm
My odometer was working but just stopped. I have replaced the gears and it works when I manually turn the gears by hand however if I plug it in it still doesn't work when driving. The speedo works fine...
Any ideas?
knapmann
Post Sat Jun 08, 2019 5:21 pm
Ok so I fixed it. I went over all the soldering on the pcb board on the back of the Speedo. On the side of the odometer area is a big coil of wound thin copper wire which at its ends coil around three metal prongs. It looks a very fragile connection. I noticed some corrosion on these prongs so I re-soldered them all together. Now it works. Not certain where the fault was in the end but it's sorted now.
BenHar
Post Sat Jun 08, 2019 6:25 pm
Well done, and thanks for reporting back with the fix.
Ben
mm1067
Post Sun Jun 23, 2019 5:57 pm
had the exact same problem with my 1989 320 cab. read this and it has saved me a fair few quid! thanks for posting. there should be 2 wrapped round the middle prong and 1 each side. 2 of them were snapped on mine so took the same approach as you (although i didnt do the soldering). works like brand new now!!!
thanks again!
