Failed MOT today.
ah
Post Fri May 31, 2019 6:38 pm
I thought I had heard a knocking noise from the front end but not had time to check it out ,knackered ball joint on no.4 http://www.realoem.com/bmw/enUS/showpar ... Id=31_0259
Foe
Post Fri May 31, 2019 6:56 pm
Will you replace the whole arm or just the joint?
ah
Post Fri May 31, 2019 7:06 pm
I'm not doing it ,my mechanic is,and he's doing the whole arm.
Foe
Post Fri May 31, 2019 7:16 pm
It's always a poo feeling when they fail, but at least it wasn't a long list or anything hugely major.
Hopefully back on the road in no time. :thumb:
ah
Post Fri May 31, 2019 8:28 pm
Yer cheers for that,to be honest it was in a bad way,the wheel had a LOT of movement,still back on the road on Monday/Tuesday.
paultv
Post Fri May 31, 2019 10:26 pm
Might be a good idea to do both sides and both bushes then you have a fully balanced new front set up, never like the idea of different aged suspension parts - just a thought
Paul :-)
ah
Post Sat Jun 01, 2019 11:28 am
I had the other side done six months ago but cheers for the advice.
paultv
Post Sat Jun 01, 2019 11:55 am
oh, should be all good then!
My car had such a collection of different aged, manufactuers and so on - including different length springs! - that made up the front suspension, I guess now I'm into overkill !!
Paul :-)
Satan
Post Tue Jun 04, 2019 4:26 pm
Should have had both done at the same time :banana: :banana: :banana:
Post Tue Jun 04, 2019 4:58 pm
Theres always one . LOL
