No workshop unfortunately, just a tiny garage.....so need to extend that!
Built myself a barn at the last house, hadn't realised just how big it was until I tried to squeeze everything into the new garage!
Have finished the mapping software!
Not much to look at, and doesn't cater for traction control yet, but now I know what I'm doing that should be easy.
Wanted to be able to map boost levels on the fly, so with this software, all you do is click on the relevant graph and it instantly maps the value to the ECU.
In the background, boost is also mapped against throttle position.
This may not work at all as an approach (target boost against throttle position) but only one way to find out.
Next step is to make up the actuators and mock up the system.
