Rounded union bolt - Front brakes
joeyb
Post Wed May 01, 2019 9:35 am
Trying to remove the flexi line on drivers side front brake (to install new braided lines) and the 11mm union bolt has rounded.
What are my options here? Is it safe to use heat here and some mole grips? Or am I going to have to replace the entire hardline back to the M/C ?
steve_k
Post Wed May 01, 2019 10:02 am
if you can find one local try this type of spanner
https://www.ebay.co.uk/itm/Sealey-VS034 ... ctupt=true
i used one a while back for the same thing & it worked a treat,
worth a try for £11 plus it always comes in handy.
steve_k
Post Wed May 01, 2019 10:03 am
i've got a full set of those upto 17/19mm & they come in handy for other jobs on the cars.
joeyb
Post Wed May 01, 2019 11:07 am
Ooh OK. Halfords have them too
https://www.halfords.com/workshop-tools ... re-spanner
In Stock at my local so I'll grab one a lunch and see if it works.
Cheers Steve
steve_k
Post Wed May 01, 2019 12:12 pm
joeyb wrote: ↑
Cheers Steve
no worries, there's that type & the type i linked to, the one's on ebay worked for me.
if all else fails cut the hard line off & use a smaller socket or irwin type nut removers.
joeyb
Post Wed May 01, 2019 12:23 pm
I’ll try the Halfords one first as can get my hands on it quicker. If I cut the hard line off, how do I make it good for a new union bolt? Never done anything with brake lines before !!
steve_k
Post Wed May 01, 2019 12:38 pm
if you have to cut it off then get a brake pipe flaring kit like this one
https://www.machinemart.co.uk/p/draper- ... aring-kit/
& a roll of either copper or kunifer pipe & some brake unions,
there's plenty of vids on youtube on how to do it,
it may seem daunting at first but after a few trial runs on a bit of the new pipe it's easy enough.
joeyb
Post Sat May 11, 2019 7:38 am
Bought some decent vice grips in the end, had the union joint off in no time.
