No Lemforder subframe bushes?
TouringMatt
Post Sat Apr 27, 2019 12:17 am
Hi folks,
It's been about 12 years since i overhauled my rear beam, and the subframe bushes need changing again.
I'm pretty sure i fitted Lemforder ones last time but everywhere i look they are showing out of stock
I don't want to poly it, but what's a good make to go for, or should i just get them from Cotswolds BMW?
Thanks!
Matt
Post Sat Apr 27, 2019 11:18 am
Autodoc show Febi and Mehyle in stock, which I'd be happy with.
TouringMatt
Post Sat Apr 27, 2019 12:28 pm
Thanks Brian, much appreciated advice 👍
TouringMatt
Post Wed May 01, 2019 7:33 pm
Brian, whats the opinion on void fillers these days?
My old bushes have them fitted, the new bushes have a thin webbing blocking the void.
Cut the webbing and refit?
Post Wed May 01, 2019 7:42 pm
Depends if you want to tighten up the rear end, or allow it to perform as designed.
The void is to allow controlled movement of the beam under lateral load, o as to introduce a small amount of rear steer to help balance the car.
