Hi,
Can anyone help me better understand how to get the weber carb tuned and running?
I have recently taken it off and rebuilt the carb with a gasket kit.
I have found some docs about tuning the carb but i am struggling to understand them as someone with limited knowledge on carbs and emulsion jets, mixture screws etc.
So from what i can see on my carb, there is a screw that sets idle, and 4 emulsion jets inside the center of the carb with different numbers labelled on them.
Any chance someone can walk me through what to tune and how? or like me a more lehmans guide? Not sure about you lot but the weber guide is so cryptic to me
Cheers in advance
James
Weber 32/34 DMTL help
e30Ambitions
Just for a bit more context, i now understand what the emulsion chambers + jets do that are in the center of the carb, and where each one should sit, however im not sure if they need adjustment at all?
