Replacement Odometer, drive cog.
loogie1
Post Thu Jan 24, 2019 3:40 pm
Hi,
The Odometer drive cog on the step motor shaft has failed, anyone know where I can I source a replacement? Also does it simply push onto the brass spline or will I need to remove the spline from the shaft?
I read somewhere Brianmoooore say he had never heard of this happening in the Uk. Usually occurs due to high temperatures, I think, as I have the heating on full because the car leaks and my heart condition, I have inadvertently created the environment for it to fail?!
Thank you in advance for any help.
loogie1
Post Thu Jan 24, 2019 3:51 pm
steve_k
Post Thu Jan 24, 2019 10:54 pm
Have a look at garagistic in the USA I'm sure they do this type of thing.
As for how it fits, sorry can't help there.
loogie1
Post Fri Jan 25, 2019 12:28 am
Cheers Steve, they look a bit different, but worth a punt if all else fails.
Post Fri Jan 25, 2019 10:32 pm
Replied to your wanted add.
Oseanosea
Post Sat Feb 09, 2019 7:13 pm
loogie1 wrote: ↑
Hi Steve, I just purchased a new set of odometer cogs from Garagistic here in the States. I have 1985 MotoMeter gauges and live in Florida, so they were powder when I bought the car last year. I’ll let you know how they work out for me. The Garagistic gears came highly recommended from other E30 owners locally as this problem is epidemic down here.
“Keep lowering your standards until goals are met.”
steve_k
Post Sun Feb 10, 2019 9:04 am
Oseanosea wrote: ↑
loogie1 wrote: ↑
it'll be good to see some feedback on these, see how they stack up.
Oseanosea
Post Mon Feb 18, 2019 3:17 am
Saturday evening I installed the new odometer gears I ordered from Garagistic a couple weeks back. I definitely recommend their gear set. The installation went very smoothly, with the exception of what’s called the E1 gear. It’s very tight by design, but installs onto the spindle that comes off of the odometer’s drive motor. Pushing it on was difficult in that and there are warnings in the directions (and all of the YouTube videos I watched) saying DON’T push too hard or tap the gear into place, for fear of damaging the odometer drive mechanism. It is recommended to hold the spindle with needle nose pliers while pushing the cog into place “firmly but gently”. It was awkward and scary, but after 20 minutes, some swearing and walking away a couple times, it suddenly popped into place. I took some photos of the old gears. They all crumbled like bleu cheese, save one which flexes like rubber. I meant to take an “after” picture of the odometer with new gears in place, but I forgot. I can you tell it looked like an odometer should look.
Oseanosea
Post Mon Feb 18, 2019 3:33 am
I found some useful videos on YouTube for removing the instrument cluster and replacing the odometer gears. Several were good, but those by Dan Cronin and Bimmer Zeit were most helpful. Garagistic provides online instructions to install the gears, but I didn’t find them as helpful as Bimmer Zeit’s. I am providing links to Bimmer Zeit and Dan Cronin’s pertinent videos. The process is the same for VDO and MotoMeter clusters. The gear sizes are different for each manufacturer however.
A photo of my finished instrument cluster is attached as well. I hope this is helpful to others running into this rather common problem. Sean
loogie1
Post Fri Feb 22, 2019 11:43 pm
I bought the drive cog from eBay for £7. removed the brass collar from the spindle as per YouTube videos. Pushed on gingerly, not on as far as I wanted to, but I didn’t want to damage the step motor. It’s working fine.
Thanks for your help.
It’s amazing how those cogs turn to cheese in hot climates.
loogie1
Post Sat Feb 23, 2019 12:12 am
No need to remove the steering wheel.
Post Sat Feb 23, 2019 9:44 am
loogie1 wrote: ↑
Definitely!
Oseanosea
Post Sat Feb 23, 2019 3:50 pm
I didn’t remove the steering wheel either. Too much work; no need. I’m glad you have your odometer back up & running!
Post Sat Feb 23, 2019 5:37 pm
Just a word of caution on removing the steering wheel, and I know this is quite obvious , but DO NOT remove all of the nut before pulling or smacking the wheel off towards yourself.
I have seen pics of people who learnt the hard way. :cool: :cool:
loogie1
Post Wed Mar 06, 2019 11:18 pm
Thanks for your help guys.
