HEAD GASKET
Tot
Post Sat Jan 12, 2019 9:26 pm
recently did a head skim as my alternator belt slipped off the pulleys,should i use oversize gasket or just standard one
Post Sun Jan 13, 2019 12:18 pm
Some body in the know will be along soon until then have a look around and post up some pics if you like.
Welcome to the zone mate :clap: :clap: :clap:
paultv
Post Sun Jan 13, 2019 5:02 pm
Hi Mate,
Well, normally you would measure the height of the head to check if it has been skimmed before, should be 125.1 mm.
If the skim removes the maximum allowed of 0.3 mm ( 12 thou inch ) of metal, then a 0.3 mm over sized gasket is available. Any more
skimming will affect the compression / valve clearances from the pistons, and cause lousy running as well.
At least, that's the theory, so check the tolerances and skim info with your machine shop.
Paul :-)
Tot
Post Sun Jan 13, 2019 6:02 pm
thanx mate,dnt hv pics at momemt unfortunately
Tot
Post Sun Jan 13, 2019 6:07 pm
thanx Paul,greatly appreciated.wl check with shop
BenHar
Post Sun Jan 13, 2019 6:28 pm
Why did you skim the head?
Alternator belt slipping would not normally require this?
Ben
Tot
Post Sun Jan 13, 2019 6:58 pm
well it had overheated for a while while cruising on the high way without noticing and was producing a white smoke so sm advice was that its usually js better of skimming the head
