h reg 316i fuel pump/relay
blingsta
Boost Junkie
Post Sun Feb 12, 2006 9:28 pm
Hello guys, my mates got a h reg 316i, he said that after parking his car up and returning to it, it wouldnt start.... ive just been down there and checked that he's got a spark but theres no fuel coming from his pipe... there is also no buzzing from the pump under rear seat..am i right in thinking that either his pump is knackered or his fuel pump relay?.. can any one tell me where the fuel pump relay is on these models as mine is a 325i and is located just opposite the power steering reservoir... his car aint got one... any suggestions pls!!
Gwynleym10
Post Sun Feb 12, 2006 9:31 pm
think there by the firewall, under the flap.
Check the fuse as well.
If this doesn't work might be the pump it self, check connections, and give it a bit of a wack like...
London 2 Cape Town
www.Overlandinthesun.com
blingsta
Boost Junkie
Post Sun Feb 12, 2006 9:35 pm
do you mean the flap in the passenger side footwell?? and any idea which fuse, although i checked all them and none were broken! but no harm in trying a fuse aswell... so u say the relay is under a flap but exactly where pls mate, and is it the only relay there? thanx
Gwynleym10
Post Sun Feb 12, 2006 9:57 pm
no there is a long flap, under the bonnet, think there are three relays under it. Sorry can't remeber which one at the mo...
London 2 Cape Town
blingsta
Boost Junkie
Post Sun Feb 12, 2006 10:20 pm
ok, under the bonnet.. drivers or passenger side pls mate? :cool:
Gwynleym10
Post Sun Feb 12, 2006 10:26 pm
kinda long in the middle.... by the ICV
London 2 Cape Town
blingsta
Boost Junkie
Post Sun Feb 12, 2006 10:45 pm
thanx, i'll look for that 2moro...
stuartgallafant
Post Mon Feb 13, 2006 10:31 pm
yeah, its on the bulk head under the black flap. it'll have two relays, one for the DME and one for the fuel pump.
if i remember rightly, the fuel pump relay is the one nearest the brake servo (left side of the car)
touch the relay and get your friend to turn the ignition on. the relay should click at terminal 15 (first stage) i think. if not it should definately click on terminal 30 (2nd stage)
