Fault in the headlamp circuit.
ChrisHC
- E30Zone Contributor
The first position on my light switch turns on the side lights as it should. But if I then turn on the ignition the dip beams come on dimly. The voltage measures 5 volts. If I disconnect the headlamps and re-measure, I get 12 volts. Does this indicate a problem with the K4 low beam relay or something else?
BenHar
Look up dim-dip on google.
Ben
Ben
ChrisHC
Well blow me, I had heard of dim-dip but had no idea it was fitted to some E30's. Searching on here, I see there was a discussion about it three years ago and a picture of the fitment, and there it is, lurking on my car.
Thanks very much, this board comes to my rescue once again, what an amazing resource it is!
The 1980`s version of "daylight driving lights" I think.lolChrisHC wrote:Well blow me, I had heard of dim-dip but had no idea it was fitted to some E30's. Searching on here, I see there was a discussion about it three years ago and a picture of the fitment, and there it is, lurking on my car.
I think they are soooooo cool.Have them on mine as well.
arrisbmw
if you got 5volts measured with the load on , should be 12 v .
you have a voltage drop , somewhere in the circuit.
bad wires or faulty relays . bad earth
you can only get true voltage reading with the load on circuit
ChrisHC
That is what I originally thought, but it is in fact the dim-dip device brought into the circuit when the ignition is turned on, I have now unplugged both resistors and the effect has disappeared.arrisbmw wrote:if you got 5volts measured with the load on , should be 12 v .
A mention in the Wiki would be useful.
arrisbmw
interesting thanks for sharing . where abouts are these resistors. could you post a photo when you get a minute .
thanks
thanks
biffer
Resistors are in a aluminium case bit smaller than a cig-packet bolted to the n/s inner-wing just behind the headlamp.
Their 2 cylindrical rubber connectors are in with the main loom on the n/s inner-wing in vicinity of ABS unit.
There you are !!!biffer wrote:Resistors are in a aluminium case bit smaller than a cig-packet bolted to the n/s inner-wing just behind the headlamp.
Never new that.lol
ChrisHC
There is a picture in this earlier thread that helped me track them down:
http://www.e30zone.net/modules.php?name ... ght=dimdip
Resistors are switched in and out of circuit by two relays fitted behind the LH side of the glovebox, just below the blue relay for the windows for ignition on/door open.
