Cabriolet rear screen blower
M3KUK
Post Mon Oct 01, 2018 11:14 am
Hi trying to get this working on my K reg cabriolet. I have just bought a spare motor and connected it up to a 12v power supply. The motor works fine but the heating element won’t get hot. I measured it’s resistance and it’s 800 ohms. This seems a bit high? Anyone know what the correct value should be?
paultv
Post Mon Oct 01, 2018 5:09 pm
well its fed by fuse 8 which is 30 amps - so maximum dissipation could be 360 watts - this would result in a resistance for the heating coil of 0.4 ohms.
In reality I expect the heater in the blower pulls no more than 10 amps - resulting in about 1.2 ohms for the coils...
in any event the 800 ohms you have would produce about 15 milliwatts of heat with 12volts going through it - enough to warm a flea - so I'd say its stuffed.
Paul :-)
HartgeH27
Post Mon Oct 01, 2018 5:22 pm
I have a couple of spares if you are interested.
Iain
07810 650 395
M3KUK
Post Mon Oct 01, 2018 7:41 pm
eBay strikes again! Sold as a good working unit!
Satan
Post Mon Oct 01, 2018 8:47 pm
Even when working they struggle......
M3KUK
Post Wed Oct 03, 2018 9:04 pm
PM sent Iain.
