I have an MOT failure on corroded brake lines. I have purchased cupro-nickel pipe, and a bubble flare tool. Can somebody confirm what nuts I need. I guess they will be 10M x 1 short, but I am not sure. I don't want to open the system and then wait for the correct nuts to be delivered.
Ted
E 30 '87 brake lines
M10 short is correct. New spring clips that fit on the nuts to fix the ends of the pipes where they join the flexibles are a good idea as well.
Ted_BNJ
Thanks very much, I will get the nuts and clips on order.
Ted
Ted
