Bmw E30 325i
Had a full service done including filters/plugs and diff oil from my mechanic
Also had a brand new radiator changed with new anti freeze
I initially noticed it was holding back and seemed a bit Static and lacking the previous performance prior to the work
The fan seems louder and is kicking in much quicker. There’s also a loud whining noise while accelerating when slightly warm
It’s not as free reviving as before and feels like it’s static And holding back
Whining after radiator change/full service
325i sport tech 2, lach silver, 1989, BBS RS 16 split rims,
[URL=http://s878.photobucket.com/user/ETERNI ... 0.jpg.html][img]http://i878.photobucket.com/albums/ab35 ... 46cc30.jpg[/img
sounds like you got 2 problems there.
1, egine performance , 2 and the noise.
1, what plugs did he fit, ?
2, ha syour car been coverted to am electric fan ?
i would take you issues back to the establishment that did the work ans say the cars not running right,
wine could be a drive belt being over tighten.
rear diff being topped up nothing to do with it .
why did you have a nes rad fitted ?
I used the NGK BPR6es plugs
The old radiator was discoloured and the mechanic said it needs changing
I am going back to the mechanic but want to give him some ideas of what he may have done wrong.
It does feel like something is over tightened because it’s not smooth and feels stuck
This was the radiator fitted
https://m.autodoc.co.uk/nissens/7284214
- paultv
Did he replace the cam belt in the "full" service?
Paul
Paul
No that was done last year and I had the same problem from a differant mechanic which he sorted out
i,m not sure what plugs to use check on wiki on here, but the rad would only need changing if the car was overheating or split and leaking coolant.
if the car not overheating the rad is fine.
sounds like the m/c has disturbed some thing when fitting the new parts.
seems a bit of a coincidence that the same issue happened twice after being workied on.
i just wondering whether some electrical connection has been disturbed
its worth cleaning the distributor cap and rotor arm too. as the electric has to come thru here before it get to the plugs via the ignition leads ( are they all on securely )
I have used the correct plugs, distributor and leads re all new and was done last year too
I will ask the mechanic and see what he thinks
Very good and competitive prices
Could a failed engine mount be causing this whining. It’s a loud screaming noise when revving and de accelerating. Also noticed the surrounding plastic around the fan damaged from being hit.
Fixed new engine mounts, still whining when it warms up slightly and on deaccelarration.
