What Have You Done To Your Car Today
mark_i
Post Sun Jun 24, 2018 6:38 am
cleaned out airvents with toothbrush and gave Tech1 a clean and feed.
paultv
Post Sun Jun 24, 2018 2:29 pm
Today my vert got fresh oil and a new filter - one of the only ones with a non return valve, like the original oem filters had, but non of the options available now are fitted with.
So, now my oil light vanishes after half a second instead of 5 seconds which can't be good for the engine.
Paul :-)
Satan
Post Sun Jun 24, 2018 3:48 pm
mark_i wrote:cleaned out airvents with toothbrush and gave Tech1 a clean and feed.
The wife's I hope when she was out.......
Satan
Post Sun Jun 24, 2018 7:20 pm
Yesterday didn't happen, today though 12v to 5v USB adapter installed and........ bonnet insulation replaced which has sat in the loft for 4 years..........
Oh and fed the leather for the rear backrest.
Post Sun Jun 24, 2018 9:47 pm
realised my mot is nearly expired , this means i get to drive it soon :D
Satan
Post Sun Jun 24, 2018 9:50 pm
Lol, to the MOT centre and back...........
Post Sun Jun 24, 2018 10:04 pm
it needs an mot for the Scottish car show july 15th ... we got 30 e30's on the stand :D
Satan
Post Sun Jun 24, 2018 10:10 pm
1 E30 transporting 29 toasters........
Post Sun Jun 24, 2018 10:16 pm
Satan wrote:1 E30 transporting 29 toasters........
you'll be surprised when the pics are up :mad:
Bonymaenjack
Post Mon Jun 25, 2018 8:37 am
Installed a Bavaria 3 Reverse 111 radio cassette along with Hirschmann aerial .Nice
Steve
Post Mon Jun 25, 2018 9:26 am
Sump gasket, wishbones, lolipops, droplinks done.
Ready for MOT on Saturday :D
webmaster@e30zone.net
billyfrost
Post Mon Jun 25, 2018 9:38 am
Rebuilt the nearside front suspension, new everything basically - most rotten E30 ever! Other x3 corners to sort next...
Satan
Post Mon Jun 25, 2018 11:16 am
paultv wrote:Today my vert got fresh oil and a new filter - one of the only ones with a non return valve, like the original oem filters had, but non of the options available now are fitted with.
Paul :-)
Had to lol at the Hi Mileage bit........
Satan
Post Mon Jun 25, 2018 12:00 pm
Need to check today to see if the foam is still attached to the bonnet or just sat on top of the engine.
Post Mon Jun 25, 2018 11:14 pm
Satan wrote:Need to check today to see if the foam is still attached to the bonnet or just sat on top of the engine.
new foam is £55 ish from oem parts on here .
ah
Post Tue Jun 26, 2018 6:23 pm
Satan wrote:Yesterday didn't happen, today though 12v to 5v USB adapter installed and........ bonnet insulation replaced which has sat in the loft for 4 years..........
What did you use to feed your leather with ?
Satan
Post Tue Jun 26, 2018 9:31 pm
I use Gliptone's Liquid Leather,
https://www.liquidleather.com/?gclid=Cj ... UgQAvD_BwE
I do feed the seams on a regular basis on the backrest as that section has a tendency to dry out and shrink then the seams go.
paultv
Post Wed Jun 27, 2018 8:38 am
Did your bonnet insulation stick? was it pre-glued or did you spray on?
Mine looks OK but doesn't stay stuck in hotter places despite new glue.
Paul :-)
Satan
Post Wed Jun 27, 2018 10:27 am
paultv wrote:Did your bonnet insulation stick? was it pre-glued or did you spray on?
Paul :-)
The left and right side stuck on but the centre section was a bit "awkward" I suppose years in the loft didn't do it any favours and I really need to check to see if its still stuck on and not just sitting on top of the engine.
The bits that didn't stick I used some 3M spray glue for foam.
https://www.vikingtapes.co.uk/products/ ... 4688199367
Gert_8
Post Wed Jun 27, 2018 12:27 pm
Drove it to work. Stefan, what alarm system have you got on your car and how does it operate? eg: does it operate when the roof is down?
Gert_8
Satan
Post Wed Jun 27, 2018 1:22 pm
Gert_8 wrote:Drove it to work. Stefan, what alarm system have you got on your car and how does it operate? eg: does it operate when the roof is down?
Sent you a WhatsApp.
Post Wed Jun 27, 2018 1:44 pm
Come on mate, tell us all......................
I may be passing yours very soon.lol
Steve
Post Sat Jun 30, 2018 9:46 am
Took the E30 for a MOT this morning, passed, no advisories. :D
Post Sat Jun 30, 2018 2:14 pm
Steve wrote:Took the E30 for a MOT this morning, passed, no advisories. :D
Living the dream Steve :cool: :cool: :cool: :cool: :cool:
Post Sat Jun 30, 2018 2:15 pm
Started her up yesterday for the first time since February , no issues here :cool: :cool:
