MAF Conversion
Ksulls
Post Wed Jun 06, 2018 2:33 pm
Hey guys, Ive done a bit of research prior to posting this and havent found anything. Can I fit a MAF, to an M20B20?
Cheers :)
Post Wed Jun 06, 2018 6:17 pm
Yes. Miller do a range for the M20 and M30 engines.
https://www.millerperformancecars.com/s ... onversions
I fitted one several years ago to a 1988 325iSE and was impressed at how much smoother the throttle response was.
Ksulls
Post Thu Jun 07, 2018 8:48 am
Speedtouch wrote:Yes. Miller do a range for the M20 and M30 engines.
They dont touch the b20 unfortunately. Would an intake kit and chip (say sssquid) provide similar benefits to a MAF and chip?
Cloggy Saint
Post Thu Jun 07, 2018 9:21 am
Unfortunately there isn't really anything that will breathe any extra life into a b20.
Brdjo
Post Thu Jun 07, 2018 12:30 pm
Cloggy Saint wrote:Unfortunately there isn't really anything that will breathe any extra life into a b20.
Unfortunately, this is true.
Post Thu Jun 07, 2018 12:50 pm
Ksulls wrote:They dont touch the b20 unfortunately. Would an intake kit and chip (say sssquid) provide similar benefits to a MAF and chip?
The sssquid chips sound expensive at $185, plus they will be set up for American lower grade fuel.
I can supply either Mild or Wild chips for the M20B20 for just £40 posted within the UK, which give the following gains:
M20B20 Mild; 7-10bhp gain. Improved mpg and low/mid-range torque, eliminates flat spots to perk up the throttle response, 6900rpm rev limit.
M20B20 Wild; 8-13bhp gain, to liven up the venerable M20B20, 6500rpm rev limit.
The standard BMW air filter casing is well designed, and really just needs a K&N panel filter to give some possible improvement over the standard BMW air filter - forget about induction kits, which tend to draw in warm air, reducing power.
Ksulls
Post Thu Jun 07, 2018 3:43 pm
I live in Australia so the sssquid chips cost even more :(. Does your Wild chip have the same mpg and throttle response as the mild? Yeah Ive decided against an induction kit for that reason.
