E30 Rear Cabby speakers
aimlessrock
Post Wed May 16, 2018 1:01 pm
as above, anyone recommend a good set of speakers that i can fit in the rear door cards.
If someone equally has a set for sale Pm me.
TIA
Gary
E30 320i Convertible (1989)
190 Mercedes (1988)
Satan
Post Wed May 16, 2018 1:12 pm
You have a four door cab?
Satan
Post Wed May 16, 2018 1:13 pm
Joking apart I have Ground Zero speakers in my car as recommended by Ian Pinder ANA Iceman.
aimlessrock
Post Wed May 16, 2018 1:15 pm
Satan wrote:Joking apart I have Ground Zero speakers in my car as recommended by Ian Pinder ANA Iceman.
lol- only 2 doors- well spotted.
Not come across this make-assume they are good?
190 Mercedes (1988)
Satan
Post Wed May 16, 2018 1:34 pm
You've never heard of Iceman?
When I asked him what speakers should I get he said Ground Zero so I got them.
Satan
Post Wed May 16, 2018 1:35 pm
aimlessrock
Post Wed May 16, 2018 2:28 pm
ah...i see why he is called iceman!
don't suppose you can remember the once you purchased buy chance- i.e model number/name etc?
190 Mercedes (1988)
Satan
Post Wed May 16, 2018 5:02 pm
Can't remember and as I got them a good few years back they have been superseded, I replaced the fronts with a set of speakers, crossovers and tweeters and also did the rears.
Got them from here,
http://www.caraudiodirect.co.uk/speaker ... 1kQAvD_BwE
aimlessrock
Post Thu May 17, 2018 10:08 am
Satan wrote:Can't remember and as I got them a good few years back they have been superseded, I replaced the fronts with a set of speakers, crossovers and tweeters and also did the rears.
Got them from here,
a hat tip to you sir.
190 Mercedes (1988)
Satan
Post Thu May 17, 2018 10:14 am
Remember though that in a cab the bass won't be great, I also used a switch in the console to power the antenna as if you aren't listening to radio the aerial doesn't need to be up and it stops the whistling noise when the roof is down.
paultv
Post Fri May 18, 2018 9:19 am
+1 for the antenna switch -
Paul :-)
aimlessrock
Post Fri May 18, 2018 9:44 am
...not seen this button before- but now want one.
is this oem?
190 Mercedes (1988)
paultv
Post Fri May 18, 2018 11:12 am
Nope! Its an old "Hazard" switch with the emblem removed and "Logo" my lad Storm designed for me, printed onto vinyl - hard wearing - been in the car for a couple of years - in - line with the aerial feed - push to raise!
I have a sheet of stickers somewhere in different colors -
Paul :-)
Kedge
Post Fri May 18, 2018 11:36 am
The aerial on my old cab automatically went up and down when you switched between the radio and CD, same with my 318iS. No idea how they were wired though.
Instagram - Kedge85
Satan
Post Fri May 18, 2018 12:48 pm
Kedge wrote:The aerial on my old cab automatically went up and down when you switched between the radio and CD, same with my 318iS. No idea how they were wired though.
Was it a BMW head unit? Mines an aftermarket one so maybe not that clever ;o))))
aimlessrock
Post Fri May 18, 2018 1:05 pm
paultv wrote:Nope! Its an old "Hazard" switch with the emblem removed and "Logo" my lad Storm designed for me, printed onto vinyl - hard wearing - been in the car for a couple of years - in - line with the aerial feed - push to raise!
Paul :-)
That looks superb- you interested in selling one of those stickers?- pm me.
190 Mercedes (1988)
Kedge
Post Fri May 18, 2018 1:15 pm
I think they both had Song head units when I bought them, then the iS got a full ICE install using Pioneer kit, but nothing was done to the cars wiring to fit that.
Instagram - Kedge85
Malky320cab
Post Sun May 27, 2018 10:49 pm
I have same issue, can you recommend a size that allows the cover to remain flat? Cheers
Satan
Post Sun May 27, 2018 10:58 pm
Malky320cab wrote:I have same issue, can you recommend a size that allows the cover to remain flat? Cheers
Take one old speaker out and measure the depth, its fiddly but you can get the speaker out just through the gap when you remove the cover.
06UZ
Post Sun May 27, 2018 11:13 pm
aimlessrock wrote:as above, anyone recommend a good set of speakers that i can fit in the rear door cards.
TIA
Gary
i can assure you to custom Premium Rear Speakers.
if you interest, check my google drive
https://drive.google.com/drive/folders/ ... sp=sharing
Satan
Post Sun May 27, 2018 11:50 pm
TIA
Gary
Its for a Vert.
paultv
Post Tue May 29, 2018 7:57 am
The problem with the vert is the tiny space for the magnet behind the speaker mount - the blasted cavity is so small.
Paul :-)
06UZ
Post Tue May 29, 2018 1:26 pm
paultv wrote:The problem with the vert is the tiny space for the magnet behind the speaker mount - the blasted cavity is so small.
Paul :-)
8O 8O
Satan
Post Tue May 29, 2018 1:35 pm
Got my Ground Zeros in with no issues.
paultv
Post Tue May 29, 2018 2:07 pm
But still 4 inch drivers, no?
Paul :-)
Satan
Post Tue May 29, 2018 2:33 pm
paultv wrote:But still 4 inch drivers, no?
Paul :-)
You talking front or rear, would need to double check.
Satan
Post Tue May 29, 2018 2:40 pm
Older version of these went in the rear,
http://www.caraudiodirect.co.uk/ground- ... extra-flat
paultv
Post Tue May 29, 2018 2:42 pm
Yes the back ones, I'm sure mine are 10cm and that's all the space there is unless you start chopping your vert to bits!
Paul :-)
