What’s this leak??
80strash
Post Sat Apr 14, 2018 5:37 pm
Hi there, my 86 auto 325i came out of SORN yesterday and passed its MOT. Last year had new cylinder head. Drove it today, ran all fine, not overheating, (although coolant light came on) and as I went to look at the coolant level saw this leak. I have minimal mechanical knowledge- what is this? Seems to be coolant, because it’s pinky brown on the tissue when I wipe around. Any idea what’s going on? Should I worry?
Post Sat Apr 14, 2018 7:29 pm
Where are we supposed to be looking?
Cloggy Saint
Post Sat Apr 14, 2018 7:50 pm
I'm guessing it's something on the under engine splash tray thing.
80strash
Post Sat Apr 14, 2018 8:18 pm
Yeah-that’s right it’s pooling on that tray. Also it’s wet above- don’t know what the part is I’ve circled
Edited images to show where it is
Cloggy Saint
Post Sat Apr 14, 2018 11:33 pm
Is it oil wet or water wet?
80strash
Post Sat Apr 14, 2018 11:42 pm
Almost a bit of both- feels like coolant probably splashed on oily area- wet but almost slightly greasy?
Satan
Post Sun Apr 15, 2018 8:06 am
Whats the power steering fluid level at?
TPS
Post Sun Apr 15, 2018 10:03 am
Oil Filter Housing? Rocker Cover Gasket?
Cloggy Saint
Post Sun Apr 15, 2018 12:01 pm
It's a bit out of the way for power steering fluid. Cam seal? Check the front of the block for a trail.
arrisbmw
Post Mon Apr 23, 2018 9:06 pm
its difficult to see in the image. top up coolant level, mark level with cold engine . then check regularly to see if you are losing any coolant from the radiator/ header tank or hoses. if your coolant light came on, do this first.
does it only leak when engine is running ?
power steering and auto box fluid is reddish brown. could be coming from a split pipe somewhere
check the engine oil for level, note, and check after a drive.
sometimes you need to clean everything down to see where its leaking from.
