Yes, really good one in white, £250.andye30nut wrote:Tech 1 rear valance?
Consolidated E30 Dismantling Thread - 316i to 325i Sport & M3...
sskoda
Sender unit for which size tank?B5234FT wrote:Hi, I'm looking for prices for:
Fuel pump and sender unit
Manual pedal box assembly
Gear gaiter frame
Black coupe doorcards
Rear trailing arms with ABS bosses
If you have any of them please let me know.
Al
Pedal box £75
No frame
No doorcards
Disc rear arms for ABS £150
andye30nut
- E30Zone Contributor
any pictures pleasesskoda wrote:Yes, really good one in white, £250.andye30nut wrote:Tech 1 rear valance?
B5234FT
I believe they're all the same? Part number 16141152266sskoda wrote:Sender unit for which size tank?B5234FT wrote:Hi, I'm looking for prices for:
Gear gaiter frame
Al
Pedal box £75
No frame
No doorcards
Is that for complete trailing arms including abs sensors, hubs and brakes?
sskoda
That should say, "fuel and sender unit, for which size tank?" but perhaps was abbreviated a bit too much. There are different types of pump&sender according to which size tank you have.B5234FT wrote:I believe they're all the same? Part number 16141152266sskoda wrote:Sender unit for which size tank?B5234FT wrote:Hi, I'm looking for prices for:
Gear gaiter frame
Al
Pedal box £75
No frame
No doorcards
Arms that is including the hubs. Calipers can be included for £10 extra each. We don't send (or recommended using) the old brakes (discs or pads). ABS sensors are not included in that price, but available.
SM
Any Mtech 2 coupe rear side pods for sale?
Ross_97
any Is interior parts ?
after set of seats, door cards, roofliner (including sunroof part), carpet
rrs
Hi have sent you a PM, in case your box is full. Do you have any M20B25 heads in stock? The one on my daily has cracked so I need a replacement asap
sskoda
No 885 heads.rrs wrote:Hi have sent you a PM, in case your box is full. Do you have any M20B25 heads in stock? The one on my daily has cracked so I need a replacement asap
sskoda
Yes, we have a black sunroof headliner, a selection of door cards, and possibly some seats but we're working on that at the minute.Ross_97 wrote:any Is interior parts ?
No carpet in stock though.
liquid079
Hi.
Don't suppose you have a Rocker/cam cover to fit an M20 2.5?
as long as the plate is fitted inside it doesn't have to be tidy.
Dan.
Dan.
sskoda
Most of the decent ones we've had have been stripped and repainted.
There might be one on the shelf not done yet. If we have any left untouched, £45 inc post within UK.
liquid079
That sounds good to me.
Let me know if you find one.
Thanks, Dan.
Thanks, Dan.
Caravanking
Hi,
I’ve sent you a pm with regards to a rear left side inner wheelarch for a 2 door part number 41141972591.
Do you have any of these available that you have cut out or that I can carefully cut out?
Thank you.
Thank you.
sskoda
Ah, got one, if you still need it.liquid079 wrote:That sounds good to me.
Thanks, Dan.
toldownhill13
Hi,
Wondering if you have a pair of rear trailing arms for disc fitment
liquid079
Looking for some spring pads for the front struts for a 320i.
Really want the thicker ones if they exist
Dan.
Dan.
sskoda
Indeed we do - ABS or non-ABS?toldownhill13 wrote:Hi,
sskoda
We'd have none in good enough condition that we'd be happy selling.liquid079 wrote:Looking for some spring pads for the front struts for a 320i.
Dan.
liquid079
No worries.
Dan.
Dan.
liquid079
I don't supposed you have a fully working front wiper motor then?
...... It's off a 320i if that makes a difference.
Thanks.
Thanks.
liquid079
Sounds good to me.
I will forward my details.
Dan.
Dan.
liquid079
Which address do I use to pay via Paypal?
Thanks.
Thanks.
liquid079
Payment sent.
Cheers.
Cheers.
krissto
Hello sskoda,
Do you have any of the parts I have listed in the 'Wanted' forum? This post:
http://www.e30zone.net/modules.php?name ... c&t=275672
Thanks,
Chris
Thanks,
Chris
sskoda
Hi Chris,
We would have a couple of steering wheels available, an M-tech 1 or an SE. That's all we could help with though.
krissto
Thanks sskoda. How much do you want for each steering wheel, incl postage to Gloucestershire, England? Is there a difference in diameter, and which do you think is better? Sorry for so many questions...
sskoda
No worries, ask away.
The MT1 is £165 inc post, and the SE £55 all in.
Diameter of both is 385mm, and better is subjective really, just depends what look or feel you are going for.
StefanAnghel
Hi
Do you have a pair of rear lights cheapest possible, the lenses can be broken/cracked..i’m interested in the bulb holders and lens casing (inner parts)
Posted to London please
