Hi all,
Just discovered a small leak on my coolant line, the main one from the thermostat to the rad.
I have looked online for silicone lines to replace these but I'm a little unsure as to which ones will work. I have a radiator which incorporates the header tank which I believe came with the engine conversion, my main concern is the silicone pipes look like they narrow and look too long, I don't want to order some to find they don't fit and I can't cut them down to fit...
Any advice would be welcome.
TIA.
