IMAG4176
IMAG4179
IMAG4180 Dropped the box . . . big bugger
IMAG4255
IMAG4256Moderator: martauto
IMAG4328
IMAG4330
IMAG4334
IMAG4337
2017-08-05_08-01-35
IMAG4257
IMAG4258
IMAG4259
IMAG4261
In short, I don't fancy it, but that's a good idea. I've the brake servo out so will have to get in there anyway.shedrool83 wrote:Fair bit done there Ronan.
Swapping the pedal box ain't fun and can be sore on the body lol.
I've just done mines and it wasn't enjoyable .
Its a good time to change the heater valve o-rings with the engine out as with a bit of effort you can get the grommet out and a socket onto the top pipe nuts from the bay if you fancy rolling about the other footwell .
I had just put my servo back in then thought i'll do themTedswagon wrote:In short, I don't fancy it, but that's a good idea. I've the brake servo out so will have to get in there anyway.shedrool83 wrote:Fair bit done there Ronan.
Is this the o ring you mean or is there another?shedrool83 wrote: Its a good time to change the heater valve o-rings with the engine out as with a bit of effort you can get the grommet out and a socket onto the top pipe nuts from the bay if you fancy rolling about the other footwell .
2017-10-05_07-27-21
IMAG4423
IMAG4570
IMAG4571
IMAG4572
IMAG4586
IMAG4588
IMAG4640
IMAG4641
IMAG4643
IMAG4644
IMAG4646
IMAG4647
IMAG4672
IMAG4673
IMAG4675
IMAG4676
IMAG4677
IMAG4680
IMAG4681
IMAG4682
https://flic.kr/p/YvHKFq
IMAG4426
IMAG4425
IMAG4424
IMAG4422
IMAG4427
IMAG4428
IMAG4429
IMAG4445
https://flic.kr/p/VvYw3Q
[/url]https://flic.kr/p/21kamwS
https://flic.kr/p/21kakgW
https://flic.kr/p/ZjZ845
IMAG4670
IMAG4671
IMAG4668
IMAG4665
IMAG4667
IMG-20180101-WA0010
IMG-20180101-WA0008
IMAG4655
IMAG4653
IMAG4476
IMAG4475
IMAG4478
IMAG4482
IMAG4479
IMAG4753
IMAG4752
IMAG4754
IMAG4758
Well, I didnt fancy it but thought it best to pull them out and have a look, so I pulled the glovebox out and all the trim panels round it until I could see this . . . .shedrool83 wrote: . . Its a good time to change the heater valve o-rings with the engine out as with a bit of effort you can get the grommet out and a socket onto the top pipe nuts from the bay if you fancy rolling about the other footwell .
