EBC GD135 rear discs problem
bfteh
Post Thu Feb 15, 2018 8:33 pm
Hi,
i want to know something, i bought EBC rear brake discs pointed grooved GD135 and EBC brake pads YellowStuff and i think i've got a problem with the rear discs because when i place the discs on the car, it's so close to the calliper carrier on the outside side and it's not the same with the genuine discs. I got a 316i m40 with ABS. I tried on another rear axle i have from a 325i sedan and it's the same. I think if i'll try on another e30 from a friend or so it will be the same. :roll:
I got another pair of rear discs from EBC and it's exactly the same... so i don't know what to do now.
Is there a problem, or guys do you think it's fine, or so... ?
Here is a video i took placing a piece of sandpaper between the disc and the calliper carrier, to show what's is going on, to show the gap is so tight.
Thanks.
